Has anyone run the Baja Designs Arc Bar?
Discussion in 'Ford Raptor Lighting Modifications Forum [GEN 1]' started by SilentShooter, Jul 8, 2014.
Sponsored By: KC HiLiTES
  1. SilentShooter
    SilentShooter FRF Addict
    3,055
    1,962
    Dec 29, 2013
    Siesta Key, FL
    Just ordered a 30" Baja Designs arc bar for a custom SVC bumper they are doing for me. Was looking to see who has experience with them. Looks like the Baja bars have a High/Low and flash sequence you can toggle. When wiring them for the raptor is it a PIA to wire this functionality?
    So the bumper will have four KC 6" Pro Sport HID's (2 Spot, 2 Spread) on the top and then the 30" Baja Arc in the center and an led cube in a fog pattern in each corner triangle.
  2. Baja Designs
    Baja Designs Supporting Vendor Supporting Vendor
    1,141
    669
    Apr 12, 2012
    The wiring is quite simple, you just have run a ground from the switch and the other leg from the momentary switch to either a chassis ground our battery ground. Shoot our tech support department a call and they can walk you through it. Let me know if you need anything else, thanks - Christian
    :everything:
    SilentShooter likes this.
  3. PropDr
    PropDr FRF Addict
    2,116
    1,113
    Nov 29, 2010
    Eugene, Oregon
    [​IMG]
  4. SilentShooter
    3,055
    1,962
    Dec 29, 2013
    Siesta Key, FL
    Do you guys have cube lights with a pattern that will work well for fog light duty?
  5. Baja Designs
    1,141
    669
    Apr 12, 2012
    [​IMG]
    Check out the Baja Designs Squadron LED, they are available in four patterns as well as amber ( great for fog). And we offer the kit linked above, to mount two in each fog pocket let me know if you need anything else, thanks - Christian
Share This Page
