I did the OEM hood graphics myself - Let me preface that I usually suck at anything like applying stickers. I used a slip solution and it was VERY easy. At least the hood graphics are very thick, which makes it easy to slide into place then squeegee. I used a solution called RapidTac which I highly recommend. I would think the side graphics would be just as easy.
You can spend the money on RapidTac if you’d like but it’s way cheaper to make it yourself:
4 drops liquid dishsoap (less is better than more)
1/2 cup isopropyl alcohol
3 1/2 cups water
use a fine mister spay bottle for the best results.
You can also purchase a vinyl application squeegee or you can just get a plastic wallpaper smoothing tool and a piece of self sticking felt and wrap a piece over the leading edge of the smoothing tool and you have exactly the same thing you’d pay three times more for if you bought a vinyl application tool kit.
The last thing I would recommend would be a heat gun. You probably won’t need it for the hood, but it might come in handy on the rear fenders because of the curves.
Google “installing vinyl graphics on a car” and watch a couple of YouTube videos. It isn’t difficult to do, I know-I did the pillars on both mine and my wife’s and also the front grill “FORD” lettering. After doing those I put a large hood piece on mine that required the use of the heat gun.
Because of the length of the OEM stickers I might recommend having a second person to hold one end so you don’t have it flopping around and getting dirty while your trying to put it on.
I’d attach a couple of pics, but I’m sitting at a helibase away from home until Tuesday so I don’t have access to my truck right now. I can add a couple of pics after I get home next week if you would like.
Good Luck!
How much are OEM hood stripes when you buy them not installed from factory?
Are there instructions on how to line them up? Seems to me that the graphics don’t really go all the way to the edge.
I got the graphics yesterday. What is “char line”?
Are these OEM? Are they thick as well? I am looking to buy a set of hood decals for my Raptor.That is exactly who and where I got mine from.
