Got the QTP 3" cut-outs on
grancuda
Keystone Lake
Got the pair of QTP 3" electric cut-outs on with some stainless tips. Ran them out toward the front of each running board. Good sound on each side & tips are not noticeable but you can slightly see them from the side.
Goofball
That looks good. Im afraid I would tear those off in short order in that location. Look like the QTP's are butterfly valve? Do they seal well?
grancuda
grancuda
Keystone Lake
Thanks! The cut-outs & piping aren't any lower than the transmission crossmember & the only offroading we do is at the dunes, it won't be an issue there.
The QTPs are a butterfly valve & they seem to seal good, you can hear very little leakage with them shut.
grancuda
grancuda
Keystone Lake
Here is how I wired up using aux 3/4 using 2 DPST 12v relays.
Flip Aux 3 till the damper is open to how far open you want then flip it back off. Run with both Aux 3 & Aux 4 off when driving with dumps open. Flip Aux 4 till you have it closed then flip Aux 4 back to off.
Reduce fuses in Aux 3/4 to 3 amp fuses in case both 3 & 4 are both turned on at the same time(don't turn them both on at same time, direct short & damage if you don't have small fuses).
