GEN 2 Go Rhino Sport Bar 2.0
aalonso
aalonso
Looks good.
Where did you get the graphics and tow hook inserts?
The graphics were inspired by my previous 2011 Raptor Molten Orange with the digital mud graphics and were produced and installed by RappyGraphics (Design N Signs) in Illinois.. the hook inserts were purchased from Amazon.
MidnightSpecial
Denver, CO
I'm usually not a huge fan of graphics but those look really good.
Good looking truck!
aalonso
aalonso
Are those lights in a fixed position or are they retractable?
The lights will be installed on a fixed position. The light bar will sit 2 inches higher. The photo shows just how the 40” would fit. I should have it installed on 11/10...
DocSpooK
Well-Known Member
TechsAzz
Helped a buddy install one on a Dodge Ramrunner few weeks ago. What a PITA! Too many separate parts.
We may have gotten an early model, had to drill several holes to mount the Rigid 40”.
CarID screwed him. Easier (and actually cheaper) to have one welded locally. Plus you have to seal it with silicone, cause its probably gonna rust.
Looks good from far, but far from good.
AF-Raptor
That Rhino Bar looks amazing. Been looking for a rack that I could make work with the BAK Revolver X2 tonneau cover. The ADD Chase rack needs too much modification. My tonneau looks very similar to yours. Will it still roll up within the width of the bar? Did you need to modify at all?
Chris in DSM
Des Moines, iowa
I have the same thing but no lights. Looks great. They do have lights that rotate up and down, but I wouldn’t ever use them. It’s nice that u can still put a cover on the bed and i get a lot of looks and great comments.
The roll up cover works just fine. Have to roll at an angle from inside the bed but it works just fine
FPBRVC
Long Island, NY
I definitely want to add the Rhino Sport Bar to my ‘19 with 4 Round KC lights.
Question about wind noise - my light rack in front of my windshield on my Wrangler introduced a TON of wind noise. I am hoping that since this is behind the cab it will be less of an issue. Did this bar introduce any annoying rattles or wind noise?
aalonso
aalonso
No wind noise at all!!
TS01
Canada, Ontario
SICK!!! Just wondering when you installed the 2.0 sport Bar. Did you use the nutserts at all? Or just the regular bolts to bolt on the rack onto the bed rail? Thanks in advance!
Viper32
I installed one on my 2014 about 2-3 months ago. I had to use nutserts with the kit. I purchased a tool to make the install of them much easier on Amazon also. Like stated the bar looks good but it is a major pain in the ass putting together and installing. I think sometime in the near future I will remove mine and weld it up and have Line X applied.
I own both a 2014 and 2019 Raptor and decided it was not nice enough to put on the 19. I will look at ADD for it, they do offer the bar with different base so you can still use bed cover by request.
TS01
Canada, Ontario
Thanks, Viper32!! Any picture of your Raptor? I'm on the fence of getting the Go Rhino 2.0. But a bit worried about how to install that Nutserts. And the 17/32 drill bit is hard to find around here. Can I use a different size drill bit if I purchase another nutserts kit somewhere else? Thanks in advance!!
FPBRVC
Long Island, NY
So i went to install my GoRhino Sportbar today and it didn’t work with my Retrax Pro cover. It would have had to overhang like an inch on each side and that didn’t look good at all. I was at Dedonna and those guys are pros. So bummed because I love the look of that think. I’d have to get rid of my cover to make it work and go a different route.
101,126
60,302
osvariitoreyes
