Gen1 Rescue
coffeeraptor
Beaumont, TX
Long-time reader, first-time poster here. I finally decided to join the community to share my journey with my Gen1. Unlike many who may have bought new through dealer, or privately etc .. my truck came to me as an auction rescue. First car was a 98 explorer and I stopped buying American after. I've always loved the gen1 and the NA 6.2 and it was a dream truck so i naturally would browse classifieds and auction listings for something reasonable.
I picked mine up as a clean title with minor damage up front from copart. It was definitely pushed around at the yard. But the history was fantastic, 200k with all the proper maintenance across the truck from last owner. they had it for 11 years and clearly paid attention. Exactly why I wanted it, good care . Came with 2 keys which both looked to have been in cases or something b/c they both looked brand new!!
Since bringing it home, the goal was to make content on it as the "CHEAPEST GEN1 in the country" capturing me bringing it back to 100% and go after a possible camper build. I did the research when i bought it and i at that point, it was the cheapest clean title that is not totally 'clapped out', rusted, bed hanging off ...
I initially focused on going through the truck to make sure it was mechanically sound. I worked through the most common areas steering rack, engine, and some glass work to get it 100%.
  • Steering: despite the abuse at the yard, steering pump was OKAY!! But fluid was low and it was noisey. i traced the issue back to the high pressure line going from pump to the rack. it was a mess down there but i had enough room so i replaced this my self with a OE line from O'Reily's. pretty straightforward, no issues after, everything perfect. the cooler seems like overkill but i get it, thought about bypassing it but lines and everything are in good shape.
  • Engine: Truck has AWESOME service history, with big services at ford in the last 5k miles. unfortunately, an oil changer reminder on the glass was from a quick lube shop which noted 5w-20. for texas, this didn't make a whole lot of sense to me. i immediately swapped in Pennzoil 5w30 with a motorcraft filter. no issues— i did call the shop —greasemonkey— and was able to verify they ran 5w-20 for at least the last 2-3 changes. NOT great, but given the intervals were between 3k-5k miles, i just moved on. Radiator was brand new OEM along with the fluid. OEM plugs, wires were just done and they even went through and did the fuel injectors. PO spent a few thousand dollars in the last 5k miles and i could see it all. i noticed the common fuse relocation was not done. Also had a fresh brake job!
  • Transmission: This was a HUGE learning curve for me. 6r80 is incredibly annoying. once i figured out how to PROPERLY check the level, i had accidentally let some escape (attempted to check while off). i broke the dipstick while attempting a proper check. bought a new one, but never opened it back up. change was done roughly 70k miles prior and i could see that it was taken in for the earth/lead issue which was addressed and fluid replaced (so maybe more like 40k ago) so i tracked temps for a while and having read horror stories and asking a few shops about how they handle drain and fills i have no confidence in any shops around me to do that services. the amount that escaped was negligable and despite buying a dipstick relocation kit i just stopped here. if i keep it another 10k miles, i would drive it to the dealer who sold it to preform that service.
  • Exterior: about a week into the truck i discovered a water leak coming in via the rear glass. i also discovered this is super common for that generation. i got sorta lucky in that i guess this truck was mostly garaged.. there was no signs that this had been a consistent issue, no rust , no stains etc. I took apart the rear glass my self and replaced the gasket with the proper 3m material. tested it and put everything back together. Running boards were missing, either the previous owner had aftermarket boards they decided to keep or just ran with none. This was a tough spot for me because in my opinion, it looks great with out. i eventually sourced gen 1 steps after going back and forth on doing gen 2s. glad i did gen1, love the factory look. Added a 20% tint to the front windows and a strip on the front glass.
  • Interior: VERY CLEAN, none of the common wear in spots i'd expect to find on a 200k truck. The nice people at the auction yard unfortunately may have taken the floor mats, spare kit, spare wheel, running boards?! i bought a factory spare tool kit (ebay) and a 2013 never used spare wheel. Blend door was replaced so no issues on hvac, sony stereo SUCKS but overall the infotainment is not bad for how old it is.
  • Front end: this truck was tossed to the yard because it had a minor hit on the lower bumper, both bumper brackets were totally fine, just bent back slightly ruining the fitment. long story short, i thought the entire front end was gone, was surprised and thrilled to find headlights, middle bumper, and grille in the bed on delivery. i was able to get everything buttoned up with no issues, all harnesses were fine. after trying to source a factory gen 1 bumper i decided they don't actually look that great. i ended up sourcing a tubular baja style bumper locally and bought replacement brackets. one afternoon with family, we cut the old brackets off , welded new ones on and put the new bumper. i think it looks great! and the factory brackets were 50$ a piece so this worked out great. As much as i would love to upgrade to 2013-14 headlights, i actually like the older factory look so it'll probably be these for while.
I’m still enjoying the truck, there’s always more to do. i'd like to address a few scratches on the tail gate and some dings on the drivers door. Plans i had were to build the swiss-army-knife of trucks :) and drive it across the country... drawers for the bed and a maybe a shell? a rack on top?? winch up front, aux lighting. I have a wish list but for now i'm just appreciating it and my kids love when we take it to the park.
I love good rebuilds and refurb projects— its what i do. i started to post some of the footage i captured to my instagram mach_garage_ and i'll be posting more as i get around to editing.
I’m excited to be part of the forum, learn from your experiences, and share progress on this project. woudl love to hear your comments and advice!
TomDirt
Hesperia CA
Yeah, that 6r80 transmission dipstick is such an obviously poor design, that should have been addressed years ago. The aftermarket extension tubes are a great idea, but only if it's secured to the engine and not the sheetmetal firewall. (Especially with the original motor mounts).
gusser
Army
Connecticut
Congrats!
Check the transmission cooler lines...if they've never been done, I'd make it a priority.
Welcome to the forum.
:favorites13:
fordrat
Navy Supporting Member
us
Congratulations, very nice welcome
101,289
60,423
HC FabWerks
