GEN 2 Gen 2 with 37s. Should I Go Back to 35s?
yans14
Virginia
Hi all, I am a longtime viewer of the forum, but this is my first post. I recently got a 2019 Raptor last fall, and I have enjoyed every second of it. Got it with 49k miles and the previous owner looks like he took great care of it. Pictures are attached.
It looks like I will need to get new tires in the next couple months. Yesterday, I brought my truck to the local tire shop to casually discuss what tires I should get when the time comes. When we went out to look at the truck, he noticed that I was running 37" KO2s. Tire size 37x12.50R17LT. I was very surprised to hear this as everything looked completely stock to me. I know that it does not mean much, but when I found this truck at the dealership, it was Ford Blue Certified. Additionally, when performing due diligence on the truck, I specifically asked the dealer if any modifications had been made and they said that that it was completely stock. A recurring theme: do not trust what the dealerships say and confirm everything yourself. I thought I looked at everything when inspecting it, but obviously I was wrong.
I know that 37s were not an option on the Gen 2s, so I started to do some research on what the previous owner did to fit the bigger tires. I have seen several forums that say the truck needs to be leveled with collars or springs, or have some pieces trimmed to prevent the tires from rubbing.
I got under the truck and upon closer inspection (and somewhat knowing what to look for), I found that I have adjustable RPG perch collars in the front. I cannot find anything else done in the front, and nothing done to the back. Am I missing anything that was done to the truck? Will just the RPGs level/lift the truck enough to fit the 37s? Will the 37s fit with the stock height in the back? I also attached pictures of the front and rear suspension items.
Since I have been driving it for close to a year, I have gotten a good feeling for how the current suspension of the truck reacts when driven. I have noticed that it handles well around corners and stays composed, but with smaller bumps it almost feels harsh and very solid in the front. When I first got the truck, I was expecting it to feel cushier when hitting smaller bumps on the road, but I assumed that it was just the offroad tires creating the feel. I read that since I have the live valve shocks, there is a chance that the previous owner did not recalibrate the ride height when installing the modifications and that in combination with the preloaded springs may be causing the slight harshness.
With all this information – thanks for bearing with me – I am looking for people's thoughts on what I should do. When the time for new tires comes, should I just replace the 37s or should I revert to stock suspension and go with 35s? Will reverting to stock make a significant ride difference?
One note that I need to keep in mind is that I have the Ford Premium Care extended warranty and do not want to have any repairs denied in the future. I already have had to use it a couple times, but I will save those repair items for another post. My local Ford dealership has not noticed that I have aftermarket suspension parts and bigger wheels. One of the items they repaired was a loose sway bar link and they replaced it under warranty with no questions.
Thank you all for your help.
Bozz
Royal Smart A$$
Nashville, TN
37" KO2's are not quite as big as a 37" MT or RT tire. Only by maybe an inch to slightly more than an inch. That's probably why they fit without rubbing.
If you go 35's, you will think they look tiny after having 37's on there for so long.
FYI, your leaf springs look flat / played out.
The rating of the tires will make more of a ride difference more than the tire size itself. I have been running F rated 37 MT's for 6 years, just went to an E rated RT tire and it's like riding on a cloud. The F's were 12-ply, much stiffer, the E's I am running are 10-ply.
BTW, Welcome to the forum. Better make an intro post and get a few pics of your Raptor up or the funny insults will start flying.
yans14
yans14
Virginia
Haha, I will definitely make an intro post. I just attached a couple other pictures as well.
Makes sense that the KO2s are slightly smaller since they are ATs and not MT or RTs. The ones that are on there now are D rated. When I get new tires, whatever size they are, I will probably go with the new KO3s.
For the leaf springs, as I took that photo I was thinking the same thing. Not sure why they would already be worn out since I only have 65k miles. I also do not do any towing and have not done anything crazy offroad with the truck. The previous owner must have been doing one of those things and I never noticed it.
I think the leaf springs should be covered under my warranty so I will take it into the dealership for them to take a look at. I hope they will not point out the level and bigger tires and try to deny the warranty work.
I definitely would like to keep the 37s because they look great, but if something breaks, I do not want Ford to deny the repair due to the modifications. We'll see what they say when I take it in after they have a closer look at the suspension. Maybe replacing the leaf springs will solve some of the stiffness on the bumps I was feeling. I still have a hunch that the shocks were not recalibrated after the collars were added.
Bozz
Royal Smart A$$
Nashville, TN
When I replaced my leaf springs with ICONs and had my shocks rebuilt, the Raptor drove like an entirely different beast. It was like a brand new truck! Like riding on a cloud.
raptorranger1
You got the truck at 49k, which is around the recommended service interval for those shocks and now you’re well beyond it. If you rebuild them you might get a bit more of the suspension feeling you’re expecting. Don’t bother with the dealer with new shocks/ rebuild unless you find that you can point out that they’re leaking. Instead, look at companies like Texas Shock Works or similar.
The leafs do look flattened out, but if I were you I’d probably just take the opportunity to put on Deaver leafs. They’re superior to stock and will improve the ride both on and offroad.
The OEM leafs were a cost-cutting measure and will never ride as well as Icon or Deavers. And the reality is if you peel off the Deaver sticker and slap the OEM sticker on them, the dealer probably wouldn’t even know it’s aftermarket
yans14
yans14
Virginia
Thanks all.
Sounds like I will need to address the leaf springs first. I will call tomorrow and set up a time this week to have the dealer look at them. If the warranty will pay for it, then I will need to have them put on whatever is covered. If they do not cover them, I will definitely go with the Icons or Deavers.
I have been thinking about getting the shocks rebuilt and agree that now is a good time to do that as well. I will look at Texas Shock Works, but I need to find a shop around me that will swap them out haha.
heybear
bend, or
do what makes you happy.
within some pretty wide bounds of lifts and offsets and spacers and tire sizes. these trucks work for for what 99.99% of people do with them.
seriously. read all the different setups that people absolutely LOVE.
so. please. don't take some internet jocks word for it. do what makes you happy for how you use you truck.
after owning the thing for better part of a year, you should know what does and doesn't feel right.
maybe start there and the group can perhaps help.
and if it all feels great. i wouldn't touch a thing.
JimmyCee
slightly on topic.. how was the performance loss for guys running 37s on gen 2’s? I had 37KM3s on my gen Juan and felt a noticeable difference in performance and mpgs. That’s what put me off from going 37s on my gen 2. My truck only hits Starbucks speed bumps nowadays unfortunately so needing glass and all that isn’t really to much of a concern like it was on my gen 1.
raptorranger1
The answer you're going to get is entirely going to depend on the tire. Not all 37s are the same size, and some 37s weigh 5-10lbs more than others. Especially when you realize people are running E-load vs C-load tires which inherently add extra weight and mostly to the outer-most part of the tire.
VELOCIE
PALMDALE, CA (LA COUNTY)
I have a 2020. I have mine on 37's. K02 37X12.50R17 LT 116S.
I have a Eibach Pro-Lift Kit for the front and stock in the rear. I do not have any issues. It might rub in the rear sometime when I do some off roading, like real off roading not just desert runs. But no issue as my wheel liners rubs are not deep at all, minor scrapes only. (I am planning to lift the rear about 1 or 2 inch in the near future)
Ive taken my Raptor to the dealer a few times for warrantee repairs and never had an issue.
I've parked next to Raptors on 35s and let me tell you, to each their own, but I can never go back to 35s, ever ever!
thatJeepguy
GA
I’m doing it in a year or 2 , reality is, tires wear out. Can always go back when they do.
However- the correct way to do
It is FRS 3.0 with ADJUSTABLE collars and more travel. Along with Deavers or Icons in the rear w/ 0 offset wheels. Or mid travel kits.
101,284
60,415
Gerth
