GEN 1 Gen 1 Oil Cooler Advice
Mvick9
Ponchatoula, LA
I know this may be beating a dead horse but I did not see a previous post regarding this.
Anyway...
2013 Raptor 6.2L
Got the infamous blown oil cooler with the milkshake surprise. Decided to make use of the aftermarket warranty and towed the truck to the dealership.
Planed to have them flush the coolant system, flush the oil, replace all coolant lines, and replace the oil cooler.
In true dealership fashion truck has been there just over 2 weeks. Today I was notified about the nationwide back order issue and that these coolers are not available with no type of eta in sight.
Did some research and could not find a Ford oem cooler anywhere.
Figure I have 2 options available as I was not able to find a gen 1 raptor at any pull-a-part type places near me.
Option 1: Roll the dice on an Amazon non FOMCO direct OE replacement cooler
Option 2: Order and install a TSP oil filter relocation kit with included heat exchanger. This option does run $750, however I would feel alot more comfortable going this way instead of using the knock off FOMOCO cooler from Amazon. Plus this option looks like it will actually cool the oil alot more efficiently over the stock cooler as well as helping the radiator out. This kit is also specifically made for the SVT Raptor and is not one of the universal kits.
Pics attached for reference.
Any thoughts and or ideas would be greatly appreciated.
Johnny Psyhos
Illinois
Hey bro, Ive got the same Cooler kit setup on my truck, only im using this cooler: https://www.mishimoto.com/19-row-dual-pass-fluid-cooler.html
and have set up the filter mount to accept the stock style filter using this adapter (only sold in Hawaii for some stupid reason) https://www.ebay.com/itm/3625473662...d=link&campid=5338805043&toolid=20001&mkevt=1
Im also using testing out 15w40 oil as recommended by a very trusted source: https://www.speedwaymotors.com/Driv...aFM23SMOB4DKVi5iRybsBc8eLsAqVOphoCnn0QAvD_BwE
With this setup, Im seeing pretty low pressures. Stock you should be 70 at a cold start idle, 30 at temp at idle, and peak out at 70 at higher rpm.
So far with my setup (using -10 A/N lines and full flow fittings) the truck only ever sees 30 psi, I switched to -8 A/N (essentially to what the kit comes with) and I got to 36 psi I then did the setup without the cooler so essentially just a remote filter, and I got 56 psi at cold start, and 70 psi at higher rpm. I will call mishimoto tomorrow to see if there is a better cooler for me to use. If anyone has any ideas feel free to weigh in. But yeah, Ill share any info I have because Quite frankly, I feel like the 6.2L is shrouded in mystery when it comes to specs and engine mods. So Ill do whatever I can to help more people learn and understand. Hopefully there can be as much of a knowledge base as there is with other engines.
With my oil viscosity, filter and cooler, I am trying to figure out which one is the issue here. Im working with the developer of this kit to find the correct solution. I will keep you updated
If anyone else wants to chime in or tell me any tips, it would be much appreciated
Johnny Psyhos
Illinois
Mishimoto was absolutely zero help, they simply told me “ we can’t give specs for specific engines” I have since changed all my lines to – eight, my hot idle pressure is 30, which is factory spec, and my high RPM pressure is 56 still. maybe I need to buy a different cooler? I have no idea.
eestrad2
CA
So you are using the TSP kit but are using a mishimoto cooler core ? Also still having low pressure issues ? Reason I am asking was because was considering buying the TSP oil relocation kit to eliminate the coolant to the oem cooler housing . Don't want to have any low pressure issues though
EricM
OHIO
I'd throw the fing fong part on there and give it a go. What's the worst that can happen? They probably made them for Ford in the first place....
Also consider the stock cooler is also a oil heater, which is WAY more important to engine longevity than cooling the oil.
eestrad2
CA
Good to know about being an oil heater . Thank you sir
101,310
60,411
kbbrownie
