GEN 2 Geisers & Deavers +3 on 35's
Mk1 Caddy
Hi everyone looking into getting this setup on my 2019. Seems like most people swap over to 37's. I want to keep my 35's with some 17 RRW's but not sure if its going to look funky. Any one rocking this setup can you post pics. PLS
Pacific Wheel
Reno, NV
Get a 35 that is true to size and it'll help. Toyo, General, Nitto are all a little more true to size. A BFG 315 might look very small.
BTW, what's the reason for the chosen ride height if you don't want to run larger tires?
Mk1 Caddy
Mk1 Caddy
Thanks for the reply, it started off by wanting to level out the truck without using collars but it appears springs will make the nose high. And it snowballed from there.
Pacific Wheel
Reno, NV
Gotcha, the Eibachs on the 2019's aren't quite as high if you want to consider those. Closer to 1.75" raise in the front. Should keep the nose down or closer to level at least.
waveslayer
CA
I don't have the springs you mentioned because I went with Fox 3.0', but I did the +3 Deavers and then shackled it back to leveled.
Love it. Kept 35" tires and I think it looks great ! d8c4d2afb4ca009edfa2be28d4d2c09f.jpg
My wife thinks I only have 3 guns
Baja Jones
San Diego
I'm with Waveslayer. I'm running the 3.0 Foxes and Deavers and stuck with the 315 BFGs. Bigger tire is more force on the tie rods and steering rack. I always say "Go big and carry spares" Another 2" of tire is a way better ride but.....
Slow6
AK
Planning to do Geiser front and Icon Rear in early July. Also plan to keep the 35’s for now, didn’t want to trim the inner fender or worry about fender damage if I stuff a tire.
AF-Raptor
Currently running the 35" BFG KOAs on the 17" beadlock wheels. Does anyone know (from trial & error) if a larger tire will fit (both on the wheels and within the fender opening) WITHOUT resorting to lifting the ride height? Please advise. TIA...
