Geiser Lift Alignment Results (Ford Dealer)
TXRaptor
I took my truck into the Ford dealer this morning to have them check the alignment after my Geisers and Deaver +3s. I know others have said it is not always necessary to get an alignment because the Geisers do not lift it enough to push the truck out of the specified ranges. I have also read the same message about the various 2.25" perch adjustments.
In my case, the center red tab on my steering wheel was turned slightly to the right (maybe 5 degrees) and the truck was wandering at highway speeds, so I took it in.
Here are the results showing my truck was definitely outside the specified range for toe.
Right: .44 (Range 0.00 - 0.20)
Left: .35 (Range 0.00 - 0.20)
Total: .79 (Range 0.00 - 0.40)
NOTE: Interesting that the rear Thrust Angle also changed, but stayed within specs.
They had no problem brining it back into spec and the truck drives MUCH smoother, with zero wandering at 80+ MPH. Plus, the red notch is dead center. :biggrin:
If you plan to add Geisers, get it aligned as soon as possible!
COMBS19
Minnesota
Same here! Brought it in twice and finally had them put the toe in at .10 and that made a world of difference. I still think it could use more positive caster on mine the best they could get it was 2.9* positive and the adjustments were maxed out. Thinking aftermarket upper control arm could get me in the 4.0*+ caster range and it would be perfect.
TXRaptor
TXRaptor
I wonder why the adjustments are so different between two trucks with the same set of Geiser springs? They told me mine was very easy and your adjustments were maxed out... :crazy:
COMBS19
Minnesota
Well they told me mine was good or with in Ford specs with adjustments maxed out but I think that's at outer edge of the good range. I think if they can they would of added more caster but there was no more adjustment left with the stock upper control arms. I would like to know what a stock truck has for caster? Thinking it's closer to 4.0* positive. It looks like Ford's acceptable range is 2.8* to 4.8* positive caster.
Tlh235
the shop i contacted about doing my geisers and deavers added it into the price of install. I didn't even mention alignment, i glad they did. Dropping the truck off tomorrow morning.
nikhsub1
Los Angeles
Just an FYI, alignments should ALWAYS be done when the front suspension is unbolted - makes no difference if you go higher or not. If you remove the tie rods chances are your toe will be out no matter what.
Ecoop
California
Yep new uca and I set mine up at +5.7 caster
TXRaptor
TXRaptor
That is good to know. Both of the shops I talked to said an Alignment was not needed because the truck would still be within Ford specs. From what I have seen so far, this is NOT the case.
HalfRap
I agree with the final part of this and tie rod part, but please elaborate on the unbolted part and how height does't make a difference??
nikhsub1
Los Angeles
When you disassemble the front suspension, UCA, LCA, tie rod etc, an alignment should be done, period. Even if you unbolted things for fun, to see how they work because you are curious and changed nothing, an alignment should be done. I did not suggest that changing height won't affect alignment, I think you misunderstood. What I said was anytime you disassemble the front suspension and alignment should be done, regardless of height.
To go a bit further - if you were able to put collars on to raise the front of the truck without unbolting anything (which is possible) by way of spring compressors, I would bet that you would NOT need an alignment. That is not to say that you should not have the alignment checked; but my bet would be everything would still be in spec.
I hope this clarifies things.
Jeff-Ohio
Cincinnati
Can you share how much it cost to do the install?
TXRaptor
TXRaptor
I paid $499 for the Geisers and $1265 for the Deavers. Total of $1764, plus $173 for shipping.
For my installation, I paid $180 for the Geiser and $330 for the Deaver +3s. Total of $510.
HalfRap
nikhsub1 I am sorry, I do agree with you 100% Now.. The way I initially read it was that it should be done with it unbolted.. My mistake,, lol!
xgardx
CLE OH
So i'm trying to get my ducks in a row as my ICON RXT leaf springs came in today, planning on doing Geisers and the icons to start with option 1 as shipped as people are reporting closer to a 2" rear lift than the advertised 1'' even after some considerable mileage and no real 'settling' of the springs noticed...
but to come to find out, i stop at my local Conrads to talk about getting an alignment , options/ prices/ scheduling, etc... and the guy pretty much stopped me after finding out that it is a newer Raptor, and that i was planning to add new springs ( change the height of the vehicle) he said that 'none of their locations would be able to work on it due to all of the adjustments/ recalibration for the ACC sensors that I'd have to take it to a Ford dealership."
now i get that yes, if you were to throw the rake off bad enough it may need the ACC realigned/ calibrated, but who has actually needed this performed on their's with doing a Geiser/ Eibach & deaver/ Icon setup?
where have people taken theres for the alignment? dealership? small mom and pop shop? dare i say 4wheelparts?
PlainJane
San Diego, California
What OP is describing is bump steer, like most cars and trucks the Raptor must have some.
The toe changes with the height of the truck. This is due to the relationship of the LCA and tie rod, both angle and location of the pivots.
Wfo
Syracuse
What is Acc? Automatic Cruz? After front springs toe will need to be adjusted, I don’t think the deavers should require alignment. Someone correct me if I’m wrong. I plan to install my deaver +3 with rpg drop shackles this morning. I took the leafs apart and had them sandblasted then I painted them with Steel-it coating for rust protection. I just got them back together last night.
xgardx
CLE OH
Yes ACC / automatic cruise control, the lane departure system/ the radar sense in the front bumper that needs moved/ realigned/ calibrated sometimes when you move up in front of a front mount intercooler when doing certain aftermarket bumpers and stuff. But this guy I think was basically saying they didn’t want to work on it due to the liability/ safety of it being a “lifted truck” and that those sensors may need adjusted as well. Even though I think they won’t with the geisers and rear leafs installed.
Just seeing where people have taken them to get aligned after installing these setups. And any issues to be on the look out for.
101,112
60,285
Selestial
