Gear shifter light
bailer
Saskatoon, Canada
Yeah, there is no indicator on those lights you pictured. I guess they are just to remind you of the gear ordering on the console.
The indicator, as mentioned, is on your center gauge display.
usernameunknown
Planet Earth
guess i worded it wrong.......those lights in the picture(my buddies raptor) above are not working at all in my truck. it doesn't matter how i configure the lights on the dash.....
Smokeshow60
SgtMajor of the MemeCorps
Southern Ohio
Turn lights on , turn dimmer for instrument cluster all the way up and cover the light sensor in middle of dash by windscreen. If it doesn't come on you have a problem. But sensor must think its dark out.
mdracer76
NoVa
I noticed mine are not coming on either. OP? Any solution? did you take it to the dealer, or some other fix?
Thanks!
I'm in a 2018 /802A
Heeblet
I don’t think those lights are there. Mine don’t light up 2018 I think just printed on the console. I just use the dash. Another forum covered this people complaining the same.
Sent from my iPad using Tapatalk Pro
gijosh28
I have an 18. Mine lights up. I would say you have a problem. I was just in there replacing my cup lighting to add ambient lighting. I was going to swap the shifter light to be color changing also.
