Gear lights disappeared
Quaesta
So I just noticed that the lights to the right of the tachometer which show what gear I am in have gone away. I am not sure if I turned them off or if something is wrong. Does anyone have any ideas?
Derail
Press the + paddle, or the + on the manual shift on the gear selector.
Quaesta
Quaesta
They are there when I am in Manual just not when in Drive.
Army
derail is right. The 1-10 indicator embedded within the dash goes away when you toggle the paddles or gear shifter to use the gear lockout feature when the transmission is in automatic mode.
This is some kind of bug, but affects the model line (F150’s) not just the Rap.
Probably an easter egg some engineer left in to see how many electrons would be slain discussing it...
In manual mode you get a different gear indicator.
jocdmd
I thought the OP was talking about the gear lights next to the gear shifter. In the Gen 1 the gears are illuminated with a little red indicator showing what gear is selected, but in the Gen 2 they area not illuminated. strange.
spg993tt
New Jersey
even when in automatic mode , if you click the right/upshift paddle it toggles the lightson and off.
and if you click the left paddle, i think that one by one lowers the trans lock gear #. it hink. when you click that left paddle the 10light goes out, then the 9, then the 8 and one by one the lights go out, which i think is showing you the gears you have available and the ones that are not lit up are 'locked out'.i think.
Quaesta
Quaesta
Thank you. Pressing the shift up while in Drive fixed it. That was driving me crazy. Thanks for the help.
OriginalToken
This is covered in another thread extensively. It is not a Gen 1 / Gen 2 thing, but rather a trim level and date of production thing. Some Gen 2's have/had this illumination as well, and up to a certain date it appears to have been tied to trim levels or options, some trim levels/option combinations had it and others did not. The last I checked the thread it was beginning to look like Ford dropped this feature entirely sometime during the 2018 Gen 2 year, probably for ease of production.
T!
Quaesta
Quaesta
T!
You are talking about a different issue. We are talking about the gear indicator on the tachometer not the ones next to the gear shifter.
OriginalToken
Yes, look at the quote I included in my post. I was quoting, and responding to, jocmdm, and he was talking about the other issue, the lights beside the shift lever on the console. As I said in my response, that particular issue has been covered in other threads extensively.
T!
OriginalToken
I say *** sake! Fix your software Ford.
Had to dig for that old post, ah?
However, fix what? I doubt it is broken, it looks intentional to me. If you press the up button or paddle when 10th is already selected the gear display turns off, for people who do not want those changing colored numbers on the dash. If you want to see it hit the up again and the display turns on.
Even my base model F150 FX4 work truck does this. As did the 2017 work truck we had with a 6 speed.
T!
Droid
kglesq's Brother
2011 did the same thing. It was a dumb design then, and it's a dumb design now. If they really want this configurable, make it a configuration setting.
Members online
101,067
60,235
bbam
Latest posts
