G2 vs '18 F150 4x4 3.5
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by Jake17, Oct 11, 2017.
  1. Jake17
    Jake17 FRF Addict
    1,026
    396
    Jan 28, 2017
    Craigy likes this.
  2. DrippinRaptor
    DrippinRaptor FRF Addict
    1,827
    1,148
    Dec 4, 2012
    Driftwood, TX
    Drag racing? *yawn*
  3. troverman
    troverman Full Access Member
    113
    50
    Sep 8, 2017
    NH
    Interesting. The engines between the two are extremely closely related. My question is "was the Raptor launched in Sport mode?" It would definitely make a difference. Also, what axle ratio did the standard F-150 have?
    I suspect the tires and weight...
  4. Jake17
    Jake17 FRF Addict
    1,026
    396
    Jan 28, 2017
    Was the Lariat launched in Sport?
    4917 vs 5697lbs
    375 vs 450hp
    :win:
  5. MatMan
    MatMan Full Access Member
    890
    437
    Jun 7, 2012
    AridZona
    Shocking!
  6. Aaron
    Aaron Meme Corps Commandant
    35
    13,164
    7,457
    Jun 13, 2011
    Tucson,AZ
  7. EricM
    EricM Full Access Member
    984
    608
    May 11, 2016
    Cincinnati, OH
    99% chance they were 3.55s. You have to get the heavy duty payload package to get 3.73s with a 3.5EB engine. 3.73s on any 15+ F150s are like hens teeth.
  8. DrippinRaptor
    1,827
    1,148
    Dec 4, 2012
    Driftwood, TX
    Exactly. Don't like it? Trade in your Raptor for a standard F-150.
  9. jabroni619
    jabroni619 Full Access Member
    933
    448
    Jun 13, 2017
    I don't think it would make a difference. Sport mode doesn't give you anymore power then standard mode, it just changes the throttle mapping and shift points (at partial throttle). When going full throttle, the engine is giving you all she's got in either sport or normal mode.
  10. bjinc
    bjinc Member
    30
    10
    Sep 21, 2017
    These results are a bit surprising; if you calculate the ostensible hp/weight ratios, the Raptor still has an appreciable advantage. You really have to wonder what kind of gas they were running in the Raptor (one supposes the tuned engine is more reliant on high octane gas and Colorado is known for their inferior gas), how broken-in the engines were, actual curb weights, etc, because once they got moving, you would assume the Raptor would start to walk on the F-150.
    Perhaps the elevation change also impacts the Raptor more? Interesting results.
Share This Page
