GEN 1 Fuse 16: HID - Passenger Side
Washington
Hey All,
I've scoured the internet trying to figure this one out, but no luck so I am hoping to get some assistance here.
I recently did a couple of upgrades to my wife's 2013 SCREW.
- Sync 3 system
- Spyder Headlights
This could be a coincidence but since installing both, the passenger headlight intermittently stays on after the truck has been shut off, to the point where we've got to pull fuse 16 to prevent a dead battery. I've replaced the headlight thinking it could've been the wiring harness and replaced the fuse. After replacing the headlight, all was good for roughly a week, but didn't stick.
he next step I'm planning on is running through FOREscan and re-inputting all of the codes.
Has anyone ran into this issue?
Thanks!
B E N
Frederick, CO
This sounds like a sticking relay to me. Did the new headlights include a relay in the harness? If so I would replace it or switch them side to side to see if the problem moves. I am not familiar with those headlights so a picture of the install or a link to what's in the box would help.
FordTechOne
Detroit
Sounds like you may have received a defective headlamp. On factory HID headlamp equipped trucks, the ballast receives Hot at All Times power from Fuse 16 in the BJB. When the headlamp switch is turned on, the BCM provides power to the headlamp on a separate circuit, which turns on the ballast. If the ballast is defective, it can continue to remain on by drawing off the hot at all times circuit (VT/RD, Pin 2 at the headlamp) even after the BCM has removed power from the control circuit.
FordTechOne
Detroit
Thanks for that. Do you know if the ballasts prone to failure?
Did the headlamps come with new ballasts or did you have to swap over the originals? It’s also possible for the circuits in the headlight to be shorted together, which will result in the same issue.
IamRonBurgandy
Washington
Update - replaced the ballasts and bulbs, not the ballasts. I am now thinking it may be a programming issue as I installed a Sync 3 system, so down the rabbit hole on Forscan...
