GEN 2 Full Race FMIC Install Guidance
afmace21
Altus
Hey everyone, looking to see if there are any other folks who have installed the Full Race large FMIC that could make give me some install pointers.
1. No matter how much I try to move that trans cooler line on the left side, it still rubs on the backside of the intercooler and bends some of the fins. I’m sure I can wrap the part of the line that rubs to provide some protection for the line and I’m sure a few bent fins won’t affect much but I can’t move the cooler any more away from it either.
2. This bracket sucks. I know not every truck leaves the factory with perfect fit and finish but between the way the cooler sits on the lower bracket that you install, and the way this upper bracket sits where the hood latch assembly is, I had to call it quits for the night trying to make this fit. I almost wonder if I got the wrong upper bracket. It pinches the latch release line because it doesn’t fit great above or below the bracket and it pinches the hood release lever spring making it bind (I started to grind away at the bracket to add some clearance but got tired).
I guess I’m just looking to see if I’m making this harder on myself than I should be or overthinking it. Fit and finish isn’t quite what I expected and the install instructions/video aren’t great but I still want to get this done!
91Eunos
Air Force
Hill country, Tejas
You’re not alone… Geoff and the gang at Full Race make some awesome products, but like all semi-custom parts, they often require some “massaging” to get the stock parts to fit with other stuff that have different shapes and dimensions, even if the attachment points are pretty much in the same locations.
1) I had to bend the lines a bit in a few places to make ‘em fit. No biggie, just take your time and don’t bend them too far at once.
2). Same issue with mine; I put in some spacers in at the top to make it work smoothly. Will try to figure out how to link to the specific post, but showed it in my build thread a few days ago.
Getting the silicone couplings and clamps on is a job and a half…they fit very, very tightly! Which is how it needs to be I suppose.
Edit: here’s a link to that specific post with pics and an embedded video link:
Edit #2: I had my hood latch cable routed incorrectly… it should run above the bracket. Once I re-routed that cable everything lined up perfectly and I no longer needed those spacers.
Looks like you already figured out how to trim the inner grill, but here’s a link to a couple things I had to work through:
afmace21
afmace21
Altus
Thank you for this and glad to see I’m not the only one that ran into some issues. I ended up grinding a notch into the upper bracket assembly so that the latch spring assembly no longer makes contact with the bracket. Not nearly as clean as your (better) solution but it works.
The other issue I’m running into now is the intercooler still sits too high on the lower bracket assembly which then causes the upper bracket assembly to sit too high and won’t align with the frame to bolt the latch and bracket in place.
My only solution to that has been to take out the much larger stock intercooler bushings and swap them with the smaller stock intercooler fan bushings and put those on top of the intercooler. This causes a little bit of “slop” in the holes of the upper bracket assembly but I think the assembly bolted down and the piping all snugged up, this will keep the intercooler from jostling around too much.
Pictures attached in case anyone else runs into these issues and needs them for reference. You can see the stock intercooler fan bushings drop the latch assembly enough to bolt it in, just causes some “slop.”
Still don’t love the contact happening on the backside of the intercooler with the trans cooler line, gonna have to play with that some more to get that to work better. Haven’t done much of the piping yet except for putting the bottom Y-pipe in and swapping my BOV and getting the throttle body pipe in place.
afmace21
afmace21
Altus
For the transmission line, undo the 10mm bolt holding it in place before trying to twist that bracket. Additionally, I found by twisting the clip holding the rubber hose clockwise with some needle nose pliers, that helped turn the line inwards towards the radiator and away from the intercooler. Additionally, I went ahead and wrapped the metal portion of the line that was rubbing with some squishy padding.
afmace21
afmace21
Altus
That was part of the problem but it still feels like my intercooler is sitting about 1/2” high. I made sure the lower bracket was flush with the frame rails, I’ve ensured the intercooler lower post and bushings are flush against the bracket holes but when I go to test fit the backside of the grill, it’s resting about exactly a half each too high even after matching the amount of trimming to the instructions.
Attached are pictures to hopefully show what I mean.
Photo one is a front on view of the grill resting on the upper bracket. I can cut more but wanted to post here first before I hacked too much away.
Second photo is a top down view of the grill resting on the bracket.
Third photo is just to show the lower intercooler posts/bushings are fully seated in the lower bracket.
full-race geoff
AZ / NJ
Hey thanks for the photos, Lower bracket looks good. But the upper bracket seems out of whack… like the holes are too low almost? Can you please send an email to [email protected] with these photos, your order number and contact info, the team will get it straightened out. Worst case a new upper bracket may be in your future, need my techs to see if they can ID the misalignment.
afmace21
afmace21
Altus
Can do, thanks for the help @full-race geoff!
Ticopowell
Air Force
Ga
Any updates on this? I'm going to install a full race intercooler soon on my 2026 and would love to hear if the issue was resolved and if it is going to affect my install.
afmace21
afmace21
Altus
I’ll try to do an update post with pictures but I was able to get everything buttoned up after some massaging of the upper bracket that reuses the rubber isolators from the stock intercooler. That was really the only part that was causing issues for me. After that, it’s getting all the piping to cooperate and getting the couplers in place. Let me know if there’s any advice I can offer!
101,310
60,412
hugecrankfonz
