BT, let's start with the simple things......when you turn the ignition to key on engine off, does the theft light icon on the instrument panel flash rapidly? If so, it is a PATS (passive anti-theft system) problem related to the transceiver receiving an invalid key code. Try using your other key as suggested above. If the light is coming on solid and not flashing, then this can be eliminated. The next two things needed are fuel and spark. Try turning the key to on and listening for the fuel pump (an audible hum). It will run for 2-3 seconds and shut off when the key is turned to key on engine off position. If no hum is heard, refer to your owners manual in the "roadside emergencies" section and locate your fuel pump fuse and relay. Beyond that, you may have to have your dealer check it. PM me if you need additional help.
FSM
i would never buy a Ford
Well then it's not the key and i don't hear the fuel pump running. I think she'll have to take a ride on the tow truck down to the dealer on Tuesday. Thanks for the information.
UPDATE: Checked the fuse #27 and changed the relay #8 - still nothing. I did stumble across a blow fuse #31 for Trailer tow park lamp relay. That could explain why my trailer lights didn't work last week.
you did check the relays right?
try the bang job?
