Front tire wear problems
Discussion in 'Ford Raptor Problems and Questions Forum' started by McDowell, Apr 17, 2014.
  1. 6point2
    6point2 Full Access Member
    26
    197
    204
    Feb 4, 2013
    Oklahoma
    Same here. Did it at low perch and it does it now at mid perch.
  2. McDowell
    McDowell Full Access Member
    28
    476
    101
    Jan 10, 2014
    Oklahoma
    Wtf
    Sent from my iPhone
  3. sanddunesaddict
    sanddunesaddict Member
    38
    33
    Aug 29, 2012
    everyone Ive put on the alignment rack(about 30-40) are toe'd out from the factory.
    I lower the air pressure to 30-33 psi and recalibrate the tpms. of course the customer has to agree to this but they are D rated tires they can handle it just fine unless youre going to be at 100mph all day long.
    also getting the tires rotated every 3k will help.
  4. McDowell
    28
    476
    101
    Jan 10, 2014
    Oklahoma
    Thanks man
    Sent from my iPhone
  5. Baja Jones
    Baja Jones Full Access Member
    55
    38
    Jun 13, 2012
    San Diego
    Everyone is missing this. The truck properly aligned at any ride height will not prematurely wear the tires. A tire sitting flat on the ground with proper toe Wears just fine, provided you are not taking exit ramps at mach II. The factory alignment slots in the frame are a worthless attempt at retaining front end alignment on an off-road vehicle. Just riding a burmed corner to hard will cause lower A arm movement and alignment change. Total Chaos Fabrication is making an eccentric lower control arm bolt with a pair of weld on guides that will not allow the lower A arm to slide when you take a shot to the bottom of the tire. Not on their web site yet but call them and get in line. Do not install the bolt on fix with the eccentric on the nut. The control arm turns the bolt and when they fall off you are screwed. Fixed a couple at TRR 14 one where the lower control arm bolt fell out. Don't let flat rate techs align your vehicle. When you bring it back after 2 weeks and 1500 miles they get charged back. So they give it a sun bath and hand it back to you. Firestone Tire stores have a lifetime alignment package for around $170. They used to cringe when they saw me coming. After the Chaos kit not so much.
  6. McDowell
    28
    476
    101
    Jan 10, 2014
    Oklahoma
    this is very helpful thank you very much!
  7. ISFast
    ISFast FRF Addict
    2,562
    961
    Mar 11, 2011
    Tulsa, OK
    Double and Triple check with what ever Firestone shop you go too! I had a NIGHTMARE come to reality when I went there to get the "lifetime" alignment. Long story short... They had to by me all 4 new wheels and didn't even get the alignment started.
  8. McDowell
    28
    476
    101
    Jan 10, 2014
    Oklahoma
    Holy shit how did u get that to happen
    Sent from my iPhone
  9. Red
    Red FRF Addict
    1,108
    387
    Aug 26, 2012
    Panhandle of Texas
    I think they scratched up his wheels.
  10. stevright
    stevright Member
    Aug 30, 2018
    seekonk
    As we speak my 2018 Raptor is in because there is cupping on this inside tread on the front tires. When it goes in for oil we rotate the tires. 10k miles on it and its very noticeable. Just looking at the front of the truck you can see how the tires are toed in at the top. My first Raptor and my last. Not at all impressed by the 3.5 liter twin turbo.
Share This Page
