Front tire wear problems
Discussion in 'Ford Raptor Problems and Questions Forum' started by McDowell, Apr 17, 2014.
  1. McDowell
    McDowell Full Access Member
    28
    476
    101
    Jan 10, 2014
    Oklahoma
    Hey guys i got my truck at 9,000 miles and then immediately mid perched the truck and then had it aligned at the dealership. I now have 15000 miles and i looked at my front tires and the inside of them are very choppy and wavy with uneven wear. I grabbed the tires to check my ball joints and nothing is wrong with them no play in my front end. So is this an alignment problem? ford is setting up an appointment with me but said i wont get another free alignment and i haven't done anything to my truck since then so would this not be their fault if it is an alignment problem?
    any help would be appreciated
  2. WRCRaptor
    WRCRaptor FRF Addict
    1,308
    786
    Feb 12, 2013
    Great Lakes
    I have the same issue, it did it on low perch with stock tire and seems to be happening faster mid perch / G.Y. Duratracs. Allinment is within stock settings also all bushings and tie rods appear to be good, Maybe aftermarket upper control arms would help but not sure on that one.
  3. Red
    Red FRF Addict
    1,108
    387
    Aug 26, 2012
    Panhandle of Texas
    If you go mid perch you do need an alignment.
  4. AZEngineer
    AZEngineer Full Access Member
    570
    302
    Sep 30, 2012
    Phoenix AZ Area
    Do you have aftermarket wheels? If yes are they lug centric?
  5. WRCRaptor
    1,308
    786
    Feb 12, 2013
    Great Lakes
    Sorry I did not state that alignment was done at mid perch change and then rechecked after 6,000 and a few off road runs one of which was snoball and is within factory specs. In most cases cupping inside of front tires can be caused by to much camber but my truck is below the max factory setting.
    I think an aftermarket upper control arm may help in terms of alignment and smother movement but I may be wrong on this. I dont care that much since I put 26,000 miles on the stock tires and another 20,000 out if the duratracs and each set still had more life in them when I sold them. The only thing that bugs me is that they get loud as they cup.
  6. McDowell
    28
    476
    101
    Jan 10, 2014
    Oklahoma
    I have the svt beadlocks
    Sent from my iPhone
  7. 155mm
    155mm Full Access Member
    176
    70
    Jan 9, 2013
    Maybe this is why the 6.2 calls for rotations every 7,500 miles, and the Raptor requires tire rotations every 5,000 miles.
  8. McDowell
    28
    476
    101
    Jan 10, 2014
    Oklahoma
    Idk becoming a nightmare
    Sent from my iPhone
  9. WRCRaptor
    1,308
    786
    Feb 12, 2013
    Great Lakes
    5k rotation helps for sure, but once they are cupped they never recover
  10. McDowell
    28
    476
    101
    Jan 10, 2014
    Oklahoma
    Why are they doing this
    Sent from my iPhone
Share This Page
