I'm guessing they got unplugged when the frontend came off to do the motor swap and I noticed tonight both fronts do not light up. Where might I look for a loose or unconnected wire?
I would think behind the fender flares. Now I'm curious. What engine did you swap in?I'm guessing they got unplugged when the frontend came off to do the motor swap and I noticed tonight both fronts do not light up. Where might I look for a loose or unconnected wire?
The original 6.2 decided it would be a neat trick to blow metal chunks and fire out of the side of the block. I found a low mileage 6.2 and replaced it.I would think behind the fender flares. Now I'm curious. What engine did you swap in?
Neh, I left the soot and dirt as warpaintBetter question is to ask if he cleaned the engine bay first...
