Front differential cold weather shudder
matrix243
Calgary, Alberta
It's -30C here and this is more evident then ever before. I can feel what I think is the front diff torsen shuddering badly on slow tight turns and even feels like traction control kicking in just driving straight. Would this be like caused by poor fluid possibly? It binds up pretty badly in tight parking lot turns. Never thought of it till now but what kind of stress does that put on the rack or power steering? Wonder if that can cut down the life of the steering system.
Sozzy12
South Idaho
Maybe water in the fluid? Incorrect weight fluid? Not sure if the torsen needs friction modifier. Anyone know?
bwep
Mass
It would not be your front diff unless you have it in 4 wheel drive. Under normal driving conditions nothing spins in there. Axel and transfer case are disconnected.
FordTechOne
Detroit
Is this with the truck in 2WD? If so, the IWEs should be disengaged, so the front axles/differential would not be turning.
EricM
OHIO
Yea, it's a real 4WD system- it all turns at the same time, you can't be making sharp turns in parking lots in 4WD. The truck is telling you to quit that shit.
It should be able to be driven in a straight line in 4WD without issue, no matter the surface. If it can't go in a straight line in 4WD smoothly like you say-something is not right.
