Front diff pinion seal leaking
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by Megabass, Jan 10, 2019.
  1. Megabass
    Megabass Full Access Member
    150
    58
    Nov 9, 2017
    1st 4 wheel drive for me and not too familiar with these issues. Noticed some residue on the skid plate and tracked it to the cv (pic below).
    Is this something I should get repaired immediately, or can I drive the truck over the weekend then have it done?
    Also, I have rpg adjustable collars is there any chance they blame the failure on the collars?
    Thanks
  2. Jake17
    Jake17 ★ REBEL LIFE ★
    1,372
    528
    Jan 28, 2017
    get on the waitin' list :wink:
    Megabass likes this.
  3. Megabass
    150
    58
    Nov 9, 2017
    I take it this is a common issue then? How long does the repair typically take?
  4. Jake17
    1,372
    528
    Jan 28, 2017
    depends how backed up your dealer is with all the other common issues :emotions33:
  5. Megabass
    150
    58
    Nov 9, 2017
    Lol okay thanks
  6. Derail
    Derail Member
    38
    10
    Jan 24, 2018
    I have seen where this has been reported, but I would not say it is common.
    Jake likes to try to induce panic into anyone owning a Raptor.
  7. Megabass
    150
    58
    Nov 9, 2017
    Yeah, I figured he was trolling
  8. goblues38
    goblues38 Full Access Member
    131
    79
    Oct 27, 2018
    STL
    block that POS and your life will be better for it.
    nh rapta owner and Raptor911 like this.
  9. tltoronto
    tltoronto Member
    18
    3
    Nov 24, 2018
    toronto ontario canada
    have you noticed any puddles of oil or has it been simple weeping? There is tons of oil in that front diff, you will be perfectly fine. Remember, the front 4wd system doesn't rotate when in 2wd, thus where a couple of problems arise from. (water filled diff oil, leaky seals, bearing failures, etc..) I would say find somewhere to put that bad boy in 4 high to heat up the fluids and promote oil movement. Sometimes, it will stop seal leaks due to the lubricants moving around.
  10. Megabass
    150
    58
    Nov 9, 2017
    No puddles. I will clean everything up and take it out for a drive on some local trails. Thanks for the advice
Share This Page
