GEN 2 Front Camera simple relocate no cutting no custom bracket. 30 min job
Cody Soele
Belle Chasse Louisiana
My add honeybadger deemed my front camera useless.
Here is my fix
Remove front grill. Requires 8mm and 10mm socket
Removal of push pins, disconnect two harnesses by hood latch and washer fluid line for camera.
Lift out grill.
Unplug harness for and Disassemble camera housing, I used channel locks for the stud and a 7’mm socket for bolts
Remove camera unit from housing.
Reassemble factory housing.
Place camera in O of ford and use small amount of quick set epoxy on top and bottom. I choose to use small bead in case I decided to go back to stock.
Allow to cure plug back in harness to camera Reassemble
I also took the time to polish my intercooler in the process.
Came out great and functions [emoji1305][emoji1303]
4145f022ad3a6144a1e6b4f7052513ee.jpg65480a935fd419eca0a08a87dd6467a5.jpg2f4b5cfe8fcfc3383cf4e125445ef2a6.jpg07d3dcc7e678443157a84d39b2896e17.jpg3ea597695c8cc4764e2deebb79a85132.jpg8254ca9545206fe91aed9da2b9d34261.jpg4dfad101e7ba9552535f5f1fafd9e677.jpg240acfee87e96d5834adfd845766a62b.jpg667323ef796dab9b98480e5e40d66f02.jpg
9d22a7489c047277d5e3d726f118f75d.jpg0ab62f707962db2bf28d431e8995d760.jpge7b0bc012a3139094c93ad6ea959b525.jpg
sobiloff
Reno, NV (USA)
Cool! The front perspective in the 360° view is a little wonky, but it beats looking at the back side of the bull bar. I might have to do the same on mine—thanks for the write-up!
