Front Axle Replacement
2011RaptorSVT
Salem,VA
I noticed that while changing the oil the other day. That one of the boots on the left front axles is coming a part. Looks like dry rot. Either way it will need replacing and Ford is telling me that the entire axle will need to be replaced. I typically do most of the repairs myself. What i am looking for is some insight on changing out the axle. thanks
Sozzy12
South Idaho
I assume you are talking about the half shaft? Very straight forward. I think 6 or 8 bolts on the inner flange and the nut in the hub. YouTube it. Should be the same procedure as an f150. Just a bigger shaft.
CV boots can be replaced and new grease packed within, but if it has run dry or gotten a lot of dirt inside the joint, better to replace the whole shebang.
Dane
Littleton, CO
Did you ever swap out your axle? I'm in a similar situation. Unless I'm missing something, I don't think there are flange bolts in the Raptor axle like a typical F150. Maybe I'm missing it somehow, but it sure doesn't look like it. I'm really hoping it's not clipped inside the diff.
coachhomer
Correct. No flange bolts. Just did this to mine on both sides. Remove the wheel and dust cap and the nut that holds the axle to the knuckle. Axle just pops out. There is a ring clip that holds it in place that is not visible until you pop it out.
Dane
Littleton, CO
Ok, cool. I'm going to be swapping shocks and and IWE at the same time, so it sounds like the axle should be fairly simple at that point. Basically just pull out the old one, push in the new one.
