Free, open-source maintenance and build tracker for Raptors (runs on a Pi or home server)
breed
Posting this here since there isn't a software or tools section, and the biggest part of what it does is maintenance tracking. Mods, if there's a better home for it, feel free to move it.
I've been building a little web app for my 2025 Gen3.5 Raptor over the last several months and just tagged version 1.0. It's called RaptorTracker. It's free, MIT licensed, and the code is on GitHub:
https://github.com/breed007/RaptorTracker
The short version: it's a build and maintenance log that runs on your own hardware instead of someone else's cloud. No account, no subscription, no app that quietly sells your data. Your records sit in one database file on a box you control.
What it keeps track of:
  • Service records with receipts and intervals. You can use Ford's factory schedule or set your own. It looks at how much you actually drive and turns "due in 3,400 miles" into a date.
  • Fuel log that measures economy full tank to full tank, handles partial and missed fill-ups, and plots you against the EPA number.
  • NHTSA recalls pulled for your model year, which you mark as affects my truck, doesn't apply, or repaired.
  • Warranties, registration, inspection, and insurance with reminders by email or a Discord/Slack webhook.
  • Fluid capacities, part numbers, and wheel torque for your generation, copied from the Ford owner's manuals with the manual cited.
  • Tire and wheel sets, plus a trail log that turns your logged pressures into an air-down card.
  • Every mod, from "researching" to "installed," with cost, photos, receipts, part numbers, and install notes.
  • An AUX switch panel that knows the factory upfitter switch layout and fuse ratings for Gen 1 through Gen 3.5 (and Bronco and Ranger Raptor), shows the draw on each switch, and flags anything that would overload a circuit, including stuff still on your wishlist.
  • Cost of ownership including the loan or lease, with cost per mile. Which you may or may not want to know.
  • A document vault for the window sticker, registration, and insurance.
  • PDF build sheet, and a PDF vehicle history for when you sell that shows a buyer every service with the odometer reading.
  • CSV in and out. It recognizes Fuelly, Drivvo, and Simply Auto exports if you're moving over.
The one I think this crowd will appreciate: it spits out your build sheet as BBCode, so you can paste it straight into your signature or a build thread. Prices are off by default unless you turn them on.
It also installs on your phone's home screen with a quick-add screen for logging at the pump.
How to run it
Easiest route is Docker. Four commands:
mkdir raptortracker && cd raptortracker
curl -fsSLO https://raw.githubusercontent.com/breed007/RaptorTracker/main/docker-compose.yml
curl -fsSL https://raw.githubusercontent.com/breed007/RaptorTracker/main/.env.example -o .env
docker compose up -d
Edit the .env file first to set a session secret and admin password (the file tells you how), then open http://your-server:3000 in a browser. It loads a sample truck on first run so you can poke around before entering anything.
If you'd rather not deal with Docker, there's an install.sh script for Ubuntu, Debian, Raspberry Pi OS, and the RHEL family that sets up everything including the reverse proxy and startup at boot. A Pi 4 with 2 GB runs it comfortably. A Pi 3 or Zero 2 W will do it for one or two trucks.
Nightly backups are built in and can copy off-box to a NAS, WebDAV, or S3. Deletes go to a 30-day trash with undo.
A few honest caveats. It's a single-owner app with one login, so it's built for your garage, not a fleet. If you expose it to the internet, read the Security section of the README first. And it's 1.0 from one guy, so I'm sure there are rough spots I haven't hit with my own truck. Bug reports and feature requests go in GitHub Issues, and I read all of them.
The user guide covers everything in more detail:
https://github.com/breed007/RaptorTracker/blob/main/docs/user-guide.md
Happy to answer questions here. If you try it, I'd love to hear what's missing.
101,389
60,448
Forgotten Image
