Fox bump shocks??
Viper01
FL
2CAA5892-F0C8-4D95-A003-1D9FC6B0C951.jpeg Just received my SVC bump kit with Fox bumps. After opening the shocks, I noticed one shock has about a 3/4 inch gap on the chrome shaft. The other shock appears normal. Is it lacking pressure or maybe bad internal components?
royCfus
Las Vegas
View attachment 119402 Just received my SVC bump kit with Fox bumps. After opening the shocks, I noticed one shock has about a 3/4 inch gap on the chrome shaft. The other shock appears normal. Is it lacking pressure or maybe bad internal components?
I would have a local shop check the nitrogen pressure
Deleted member 12951
Guest
This
Something is wrong with the top shock in the picture. Either no nitrogen and/or broken seal. Nitrogen should be extended the shaft
cwylie
They generally don't send them charged. You just need to charge them.
roostinyfz
All my Fox bumpstops have been charged. I had a set like this I had to send back.
brettmess24
Send them back, I had a set that was leaking and sent them back to SVC.
Viper01
Viper01
FL
That’s what I’m doing. I ordered this bump kit two months ago and to finally receive it like this is a bummer.
brettmess24
I hear you, you can still do the install as the shocks are the last part to install, no real off road until you get the shocks on.
I’m sure you will have a new set from SVC in less than a week with a return label.
