Fox 3.0 on Ebay
Bull
I've been seeing alot of stock units from the Gen 2 on ebay for really cheap, like $650 for a full set.
The Sellers state they are new take off's and the location is in Dearborne so I think they are legit.
Does this seem right or are they possibly reman units?
Johndeere99
Worked for me. Purchased mine from cbautopartners on eBay. $630. Put them on my Gen 1.
Figured if they were good enough for my Gen 2 they would be good on the Gen 1 too.
Robtor310
Redondo Beach CA
Not a bad deal since its about $500 + shipping for a rebuild. I might pick some up and keep em in the garage for a year or 2.
Pacific Wheel
Reno, NV
I thought the fronts did not work on the GEN1?
Johndeere99
They will work with a little work. There is a few helpful videos out there that help. No big deal you just have to use the coil springs and tops with the longer studs off your old shocks. The 3.0 springs are just enough bigger around that they have
some clearance problems. Have had mine on about 10 days and no problems. They will raise your truck about 1.5" due
to the longer length of the 3.0.
Tx State
Well-Known Member
is that 1.5 inch raise with factory gen 1 springs or did you put gen 1 geiser springs on as well?
patrapt
french Polynesia
hi jonh, I m a new member in this forum , and I have a 2012 ford raptor., and time to rebuild shock ( 76000km)
since the introduction of gen 2 shock on your gen 1, have you had any problem about your transmission before, and you bring other modifications on the front suspension, I would like to have your judgment, because in view of the prices of a fox shock set oon eBay , I would like to do the same installation.thx for your help.
Wfo
Syracuse
I got set set of front oem from an 18 for 150 shipped on eBay. I couldn’t believe it!
Johndeere99
Pat,
I've had mine on for 5 months with no issues. I don't off road, rock climb of leave the ground with my truck intentionally.
If I want to cross a ditch or other obstacle that comes by in the course of a day, I do it. I drive mine daily on the farm. There
are many post saying don't do it. If I were using my truck truck in a rougher fashion I would be concerened about the issues
mentioned in other post. I think you have to be your own judge. I believe if you just use it and don't abuse it you will be ok.
But if you like to rough house your truck, (I know it was made to play) I would probably go a different direction.
Bull
Bull
No Way, i need to figure out what i'm going to do soon, I can hear my rears getting louder.
Droid
kglesq's Brother
Wow, seeing these are 880 right now for full set of new takeoffs...do these just bolt right on to Gen1's? I had been planning to have my stock 2.5s rebuilt soon.
Bull
Bull
The Rears bolt right up but the Fronts require you to use your old Springs i believe.
waveslayer
CA
I have some OEM Gen 2 shocks with RPG collars on the fronts if you are interested, and the leafs springs.
My wife thinks I only have 3 guns
Members online
101,111
60,284
Don C
