FORscan Subwoofer settings
Discussion in 'Ford Raptor Audio/Video/Electronics Forum [GEN 2]' started by sswails1, Nov 27, 2019.
  1. sswails1
    sswails1 Member
    4
    Nov 27, 2019
    PA
    I’ve read that people are changing settings within FORscan and getting good results from the B&O. What settings are being changed besides enabling the aux subwoofer setting?
    thanks,
  2. SCMike
    SCMike Full Access Member
    161
    88
    Sep 29, 2019
    San Clemente
    That’s all you need to do. I made this change in forescan and it was a night and day difference.
  3. sswails1
    sswails1 Member
    4
    Nov 27, 2019
    PA
    Has anyone tried the following?
    727-01-02 0A88 C3 CrewCab with 7 Speakers & Kicker Sound
  4. BDF
    BDF Full Access Member
    230
    22
    Sep 15, 2017
    I have the factory sub amp (B&O) but aftermarket sub and box, should I do something with forscan for it?
  5. sswails1
    sswails1 Member
    4
    Nov 27, 2019
    PA
    I would think so to prevent the bass roll off at higher volumes. I think the setting mentioned with the aux subwoofer enabling gets rid of the bass roll off from past posts I’ve seen.
  6. BDF
    230
    22
    Sep 15, 2017
    Sweet, I'll give it a go!
  7. K223
    K223 FRF Addict
    2,199
    823
    Sep 15, 2019
    Florida
    Yes if you change your sub/amp setting to aftermarket with ForScan, the sub volume will increase with the rest of the system and not roll off. It made a nice difference in mine and at least your can push the sub for all it has at higher levels. It won’t be a 10 or 12” with a 500 watt amp pushing it, but it helps for sure.
  8. BDF
    230
    22
    Sep 15, 2017
    Ok, so I have all aftermarket speakers and a sub box running off the factory amp.
    I changed the setting for the kicker sub noted above, it does help with the roll off.
    It seems to negatively affect sound quality tho.
    Sound seems kind of dead, also seems to cut the highs out of the door speakers where i have 3 way 6x9s.
    Any thought on other settings to try to let everything run wide open?
  9. sswails1
    sswails1 Member
    4
    Nov 27, 2019
    PA
    Did you only change the sub setting? What about the -
  10. Fender
    Fender Full Access Member
    505
    135
    Jul 1, 2017
    Can you guys elaborate on this? Cant find much info on it
Share This Page
