How often does your alarm go off? I’ve had my truck almost a year and it went off exactly once.
Check on your Sync under Vehicle and see if your ESN displays a serial number or if it’s blank.
I had the same issue and had my onboard modem changed and it’s been working great since.
I have the shock sensor set to maximum sensitivity. I know too soft, but I like the warning beep and if someone pulls the handle to see if it’s open or tampers, it will let them know. So I get my share, when I’m parked in garage, near a train or loud car. Anyway I’d like to know and want it to work.
How do you set the sensitivity?
I'd delete the app and reinstall. If it still doesn't work, delete the link from in Sync and set back up from scratch. If that doesn't work, call the dealer.
Sensitivity won't matter, if the alarm gets set off it should send a notification to the app. For what it's worth, mine is set to lowest and I still get notifications if it's triggered.
I will remove and reinstall the app. You mean remove FordPass from Sync?
