Ford remaps 5.4 transmission
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by whtrapta, Jul 19, 2011.
  1. whtrapta
    whtrapta Ostrich Wrangler
    29
    5,489
    916
    Jan 17, 2011
    Bolivar/Springfield, MO
    I brought my truck in to get the clunk fixed. They looked and my drive shaft wasn't clunking. They DID notice that ford has sent out a computer update for the 5.4 transmission. It supposedly changed the way the clutch acts, and shift mapping up and down through the gears. I got but had to immediately go to work which was right around the corner, so no test drive. Later that night heading home I got to see the difference.
    HOLY GOD! Its so much better now. There is no gear hunting, regular driving shifts are firmer, but much smoother. I did a 0-75 pull and DAMN! It sets you back in the seat pretty hard now. I jumped on the highway and the dreaded lag time when passing is no longer. Throttle is immediate and shifts to the CORRECT gear the first time. Everyone with a 5.4, get your truck to the dealer!
  2. IRONMAN
    IRONMAN Administrator Staff Member Admin Super Mod
    9,042
    2,378
    Jun 21, 2010
    MICHIGAN
    Hmmmm well I do have the 5 star tuner wonder if I should do this or they will notice I have had a tune.
  3. Droid
    Droid kglesq's Brother
    1,159
    285
    Sep 25, 2010
    ...and trade it in on a 6.2! :lol: (j/k)
    I don't know how Fords work in this regard, but my best guess would be it gets overwritten. Not sure if Fords have separate programs for transmission and engine control....99-06 GM fullsizes had one shared program/calibration, but 07+ had separate items for ECM and TCM. ]
    Reverting to stock would be the best bet. Trouble is that when you apply the 5-star tune afterward you may wind up with the old TCM calibrations again. I'd suggest calling 5-star on it.
  4. Raptor Retrofit
    Raptor Retrofit HID Specialist Supporting Vendor Supporting Member
    44
    1,970
    1,173
    Jul 22, 2010
    NY
    Good info bro, thanks. Im calling my dealer tomorrow.
  5. jdowens1
    jdowens1 Ford Senior Master Technician
    553
    28
    Feb 6, 2011
    Montana
    A lot of tunes can be picked up by Ford Computer that technicians use if they look for it. Before you have ford do any programming you will always want to remove your program and return it to stock. Some programs once the program is written and a dealer reprograms it can leave you with a blank tuner. I am not sure if that is how the 5star will work but I've seen it happen many times with Edge products. If your tune changes the trans shift strategy you might not notice a difference with the Ford update but only way to find out is give it a try.
  6. Raptor Retrofit
    44
    1,970
    1,173
    Jul 22, 2010
    NY
    So are there any reference numbers for this. The guys at my dealership are clueless. I can almost guarantee the will know nothing about it.
  7. whtrapta
    29
    5,489
    916
    Jan 17, 2011
    No, they just told me what it does on the phone. they said it helps "some" of the trucks. It worked on mine for sure so it should work on all 5.4 raptors.
  8. IRONMAN
    9,042
    2,378
    Jun 21, 2010
    MICHIGAN
    I would definitely plan on returning the truck back to stock, just the hmm factor of should I with the possiblity of them finding out I was using one.
  9. BIRDMAN
    BIRDMAN Birdministrator Staff Member Admin
    12,923
    6,142
    May 16, 2010
    Boston
    can we get one of the techs to look in to this for us?
  10. whtrapta
    29
    5,489
    916
    Jan 17, 2011
    I believe YOUR avatar says admin, sooo your the one with the contacts :D
Share This Page
