Ford Raptor Third Brake Light S S M
BIRDMAN
Birdministrator
Boston
SSM # 21317 is to replace the high mount stop light assembly due to water intrusion and possibly cauing Hill Decent Control Fault.
At this time the SSM appears to be Raptor specific.
Thanks danmpe!
ref:
The SSM # on this is 21317 to replace high mount stop light assembly. This is what is listed on my invoice when the work was done.
FSM06
Colorado
Oasis special service message number: 21317
message title: 2010 svt raptor - hill decent control fault and dtc c116a
applicable vehicles :
2010 truck : 00029 f-series ld
oasis message :
Some 2010 f-150 svt raptor vehicles may exhibit hill decent control fault with
abs dtc c116a. On vehicles built before 2/26/2010 only, inspect the high mounted
stop lamp for evidence of water intrusion. Refer to wsm section 417-01 for
replacement details part number al3z-13200-a. Torque screws to 1.5 nm / 13
lb-in. No water intrusion follow wsm section 206-09, pin point test i. Note: It
is normal for the brake pressure (brakpres) pid to occasionally spike high due
to test pulse sent to the pressure sensor by the abs module. In addition, brake
pressure signals as low as -225 psi without brake apply should also be
considered normal. .
Applicable symptom codes :
200000 electrical
206000 electrical warning indicators
300000 chassis
301000 chassis service brake system
fsm
