Ford Raptor Ac not working and Aux Switches glitching
brianmurph17
Marco Island, Florida
So today I was heading to work and I noticed in my 17 raptor that the ac wasn’t working. I also noticed that when the air was light up on the 2h on my dash and on the knob was flashing. The aux switches were also slowly flashing with a light beep each time it flashed. If anyone knows what this could be please let me know.
Thanks
Brian
FordTechOne
Detroit
Do you have aftermarket equipment connected to the aux switches or anywhere else on the truck?
FordTechOne
Detroit
Yes I do. I flipped all the aux switches on and off and the problem was solved
Check all of your wiring, especially grounds. Nothing aftermarket should be tied into any factory wiring except for the designated aux circuits. All wires carrying current need to be isolated from the factory wiring/harnesses. Did you use factory grounds for your equipment? That can cause issues as well.
B
brianmurph17
I have all the grounds connected to the negative terminal on the battery
DocTon
OK
Brian, what did you find out to be the issue? I just had this happen with my 17 Raptor. 2H is flashing, AUX lights are slow blinking and my A/C is being strange.
Please
