Ford Performance Oil Filters Leaking
JCT
Vermont
I’ve used several different oil filters on my Raptor. I’ve used the stock one and a Royal Purple one with no issues at all. However, I’ve used the Ford Performance filter twice and not consecutively. Both times the Ford Performance filter started leaking. Has anyone else had this issue?
Note that I’m terrible about lubricating the gasket before I tighten the filter down. Curious if that is the cause or if there is a known issue with these filters.
isis
PA
I mean, thats kinda part of the process for any filter so not sure where this convo will go but you’re already doing it wrong?
isis
PA
May the bigger diameter makes it easier to overtighten. Or is it just longer? I forget.
10SpdsOfFury
Jacksonville FL
I do lube my FP filter and also now my Amsoil filter with no issues. I vaguely remember FordTechone saying the Ford procedure doesn’t say to lube the gasket.
J
JCT
Vermont
Oil filter should be snug but not gorilla snug, just sayin.
I’m hand tightening the thing, so hard to understand how I would be over tightening. But, maybe I don’t know my own strength?
2020FordRaptor
Nevada
Yeah gaskets can be the cause of the leaking problem.
BigTaco
Grants Pass Oregon
They leak, I’ve had 2 of them do this same thing on different vehicles. The FL500S is a great filter. Have used it on my Boss 302 Laguna for a decade without issues. They are easy to find everywhere as well.
HighHP
E WA, N ID
I have had a couple of filters leak. However, it was the gasket in each case. If you don't lube the gasket it may not seat properly when tightening???
