I did a little poking around and didn't see an exact scenario like this so figured I'd post here.
This morning on the commute, I was merging onto the highway and floored it to get around a guy going 25mph and the engine made a wheezing noise, power was limited, and the check engine light started flashing. It went away after a couple minutes and I had no other issues accelerating during the ride to work.
Truck is stock 2022 - no tunes or mods whatsoever - with about 6200 miles. I usually run normal mode for everything except exhaust which I set to sport.
I don't have a code reader, but also is it going to throw a code if the light isn't on? Not sure what the best path forward is, but this is a little disappointing so early into ownership.
Thanks!
Thanks!
