Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Fender Modification to run 37's with 1.5" Collars
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by jwpres, Jun 19, 2019.
  1. jwpres
    jwpres Member
    30
    63
    May 27, 2018
    Tempe, Arizona
    I did this modification a few months ago. My goal was to maintain the lowest stance as possible. I also wanted to maintain factory ride characteristics. This is my second Raptor, had a Gen1 for 4 years before buying my 2018. After these upgrades I have had the opportunity to drive my truck fairly aggressively off-road with zero rubbing or other issues. In fact, I was conservative with my tire choice and wheel offset. There is enough clearance to run a larger 37" tire and more aggressive offset.
    In front I'm running Icon's Attitude Adjustment Collars at the 1.5" setting. In the rear I installed Icon's Multi-Rate Leaf Spring set at option 1. I also used SDHQ 1" lowering shackles. This essentially gave me the factory height in the rear and raised the front 1.5". This gave me about a 1.5" rake front to rear. I also installed SVC's adjustable bump system.
    Tire choice BFG KO2 37x17x12.5
    Wheels ICON Rebound 17x8.5
    I'm really happy with all of my choices. This forum was a ton of help, I spent hours researching my decisions. My truck is my daily driver and is used for towing duties (6,000 to 7,000 lbs) as well. I also like playing in the desert and I plan on doing trips to Baja.
    [​IMG]
    After Suspension Mods and Factory Wheels and Tires
    [​IMG]
    With 37's and Bakflip Bed Cover
    [​IMG]
    With Bed Rack, 2 full size spares 10 gallons of fuel and 2 10lbs Power Tanks., settled 1" in back
    [​IMG]
    Prior to modification tire rubbed on fender liner prior to full lock. Now I have at least 1 1/2" of clearance at full lock.
    xgardx, Maintecheib, Big Blue and 3 others like this.
  2. jwpres
    jwpres Member
    30
    63
    May 27, 2018
    Tempe, Arizona
    [​IMG]
    Before trimming begins
    [​IMG]
    I have trim about an 1 1/4" from lower fender
    [​IMG]
    [​IMG]
    Cutting inner pinch weld
    [​IMG]
    This is what I removed
    BBLV, Maxxed Out, BHook and 1 other person like this.
  3. jwpres
    jwpres Member
    30
    63
    May 27, 2018
    Tempe, Arizona
    [​IMG]
    [​IMG]
    Here I have re-bonded lower lip of fender
    [​IMG]
    Modifying Fender Flair
    [​IMG]
    Heat is used to reshape flair before bonding it back together
    [​IMG]
    [​IMG]
    Backside of the repair
    [​IMG]
    Outer repair ready for paint
  4. jwpres
    jwpres Member
    30
    63
    May 27, 2018
    Tempe, Arizona
    [​IMG]
    [​IMG]
    Welded void in pichweld area
    BBLV, BHook and Wfo like this.
  5. jwpres
    jwpres Member
    30
    63
    May 27, 2018
    Tempe, Arizona
    [​IMG]
    Finished product. No trimming of fender liner, wanted it to look factory
    [​IMG]
    [​IMG]
    Plenty of clearance now
  6. dubya_raptor
    dubya_raptor Full Access Member
    92
    63
    Nov 1, 2018
    Exceptional work bro!
    jwpres likes this.
  7. Loufish
    Loufish Full Access Member
    60
    755
    380
    Dec 30, 2017
    Burbank CA
    Very nice work!....those Bronze wheels do look good with the Blue...
    jwpres likes this.
  8. Wfo
    Wfo FRF Addict
    1,257
    747
    Sep 22, 2013
    Syracuse
    Excellent work!
    jwpres likes this.
  9. crash457
    crash457 I'm Batman Supporting Member
    2,355
    1,894
    Aug 4, 2016
    St. Louis, MO
    Nice. It looks factory.
    jwpres likes this.
  10. tomtom
    tomtom Member
    25
    8
    Oct 29, 2018
    Calgary
    Great work, looks like a real professional job and able to run 37" Tires with-out a big lift kit.
    jwpres likes this.
Share This Page
