GEN 2 Fabtech 4 inch lift on 2018
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by DentalDoc, Feb 12, 2020.
  1. BillVickers
    BillVickers Member
    14
    5
    Aug 24, 2019
    Dallas
  2. Droid
    Droid kglesq's Brother
    1,163
    287
    Sep 25, 2010
    I agree completely, and also I think the California would benefit equally from a 4" lift and 22s. Blend in or stand out! All the poors here are just jealous.
  3. DentalDoc
    DentalDoc Member
    27
    12
    Nov 21, 2019
    Orem, Utah
    Yes. We live in Utah. That photo was from the lions back trail.
  4. ProfZeus
    ProfZeus Member
    7
    5
    Oct 26, 2019
    Golden, CO
    @DentalDoc - It all depends on what your goals are. If that is the look and functionality you are going for, then great.
    However, with the route you took, you do diminish the off-road capability of a Raptor (I don't think this is deniable?). Additionally, I believe there are added reliability concerns with the suspension if you off-road it aggressively. That shock extension is a major weak point. Assuming they just added an even longer block in the rear to get that lift? If so, that is ridiculous and will make one of the notorious Raptor problems even worse. For the money you paid for that lift, you probably could have done other things that would have resulted in increased capability of the truck. Perhaps you won't push the truck and expose those weak points. Also, I would suggest not driving someone else's Raptor that was lifted correctly, otherwise you will feel the shortcomings of yours and it will be hard to ignore.
    But if that is what you wanted and you like it, then who cares what others think.
    DentalDoc and SS308 like this.
  5. Fshnrig
    Fshnrig Full Access Member
    67
    64
    Jan 4, 2020
    Snohomish, WA
    punctuate much?
    DentalDoc, Johnkn and MattHamby598 like this.
  6. Pure745
    Pure745 Full Access Member
    114
    91
    Dec 13, 2019
    Orange County
    HAHHHHAHAH!
  7. FL4x4
    FL4x4 Full Access Member
    52
    31
    Sep 14, 2019
    Orlando, FL
    https://fabtechmotorsports.com/product/4-system-k2263/
    2017-19 FORD F150 RAPTOR 4WD
    Fabtech’s 4" System for the 2017-19 Ford F150 Raptor provides increased suspension height which allows the use of 37" tall tires and retains the factory SVT control arms and Fox Shox.
    This 4″ system features heavy duty ductile iron steering knuckles designed to handle 37" tall tires with the vehicle’s ESC (electronic stability control) and Traction Control. Typically 37" tires will cause steering and brake issues on the factory Ford steering knuckles. Fabtech knuckles are designed for the oversized tires and will provide years of trouble free service.
    The Raptor SVT control arms are relocated with 1/4" thick steel Crossmembers retaining the travel features of the vehicle for offroad use. The factory Fox Shox are also retained with super stout front and rear shock extensions. To keep the front CV angles proper with the new ride height the front differential is relocated and comes with a 1/4" thick steel skid plate for protection.
    FOOTNOTES
    14. Cannot use OEM wheel and tires.
    55. Must use 18″ wheels or larger.
  8. nikhsub1
    nikhsub1 FRF Addict
    1,601
    970
    Mar 5, 2017
    That explains why every lifted truck is brodozerd out. Thx for the info!
  9. 500mag
    500mag Full Access Member
    347
    164
    Mar 22, 2019
    Georgia
    I wish you could use OEM wheels with that. Awhile back, my local off-road shop that I use for tires, levelling, etc. quoted me $6000 for the lift, new wheels and tires and labor, not including the bumpers.
  10. Jakenbake
    Jakenbake Full Access Member
    321
    269
    Sep 20, 2017
    Do the Gen 2’s come with SVT control arms?
    RDFTS likes this.
Share This Page
