Extend Wheel Speed Sensor Cable?
NotStock
Canada
Hey, so I installed my extended brake lines to go with the 4.5 deavers and 2" extended shackles, but now my wheel speed sensor and diff lock wires are tight at full droop. Do people extend these or am I missing something?
Canuck714
San Antonio TX
I dont recall having any issue with length on those wires. I'll climb under and take a look, maybe I unclipped something or cut a zip tie off to get slack.
N
NotStock
Canada
Thanks, I appreciate it! Emailed Casey at RPG today and he suggested they only need modification once you get into the RST18 (I assume this is true with any bypass rack system). The reason I went with the 4.5s and shackles is to eventually get into a bypass rack, so I'd like to see what people are doing to extend the wheel speed sensors and the diff lock wires.
