Ever seen this happen???
Discussion in 'Ford SVT Raptor General Discussions [GEN 1]' started by XCReapor, Mar 2, 2021.
  1. 1BAD454SSv2
    1BAD454SSv2 Full Access Member
    629
    608
    Jan 8, 2019
    HELL I ZONA
    From the cover it looks like the center pin came loose from spiders started walking out , thrashed cover. That chewed up slot lines up with about where pin is.
  2. Ricoman
    Ricoman Full Access Member
    797
    627
    Feb 23, 2019
    WASHINGTON STATE
    Nope,never seen a Differential blow thru a cover,but I did put 2 Rods thru the Block and Oil pan of my 383 stroker motor,and that wasnt a pretty sight either.>!!:bawl:
    Sounds like I caught my whining sound BEFORE I got to the mess you got.Had a bad bearing and small chip on gear...had entire Differential rebuilt for $1200,which I thought was a good price,and put a Dana Cover on,so if it ever does blow will it be contained .. ;)
    BenBB and CoronaRaptor like this.
  3. mprice1234
    mprice1234 Full Access Member
    62
    555
    432
    Oct 26, 2010
    Colorado Springs, CO
    That was one hell of a blow job with an explosive ending! Just to bad not the one you wanted. One thing for sure it won't be a cheap fix.
  4. 1BAD454SSv2
    629
    608
    Jan 8, 2019
    HELL I ZONA
    Yep
  5. MTF
    MTF FRF Addict
    4,810
    1,605
    Nov 27, 2010
    NYC
    Nice, if your gonna do it do it right. LOL
    Cooked all the inner bearings at 20,000 miles, had it warrantied, thank goodness, it was close to $3 grand to replace everything.
    Now I have an AFE cover and Mobil 1 gear oil, all is good now.
  6. XCReapor
    XCReapor Member
    26
    14
    Jan 29, 2018
    Albany, Ny
    Dreading this repair cost... I will update when I find out how much it will be.
    1BAD454SSv2 likes this.
  7. Jakenbake
    Jakenbake Full Access Member
    675
    495
    Sep 20, 2017
    If it gets too expensive there is always a full float rear end that can be thrown in there........... which will be more expensive.
    badm0t0rfinger likes this.
  8. 1BAD454SSv2
    629
    608
    Jan 8, 2019
    HELL I ZONA
    I definitely considered the currie. But for few grand less than the currie i got stock axle completely rebuilt plus front suspension work 4 new ball joints new iwe and leafspring work as well as new mounting for the axle anti wrap bar. OP be sure find good shop with good warranty
  9. BlueOvalF22
    BlueOvalF22 FRF Supporting Member Supporting Member
    194
    181
    Jul 31, 2020
    Willow Springs, CA
    Launched one out the side of a 4G63 block. The GSX was tuned for 1/4 mile in the summer not subzero rally car driving.
    Ricoman likes this.
  10. John813
    John813 Full Access Member
    844
    470
    Feb 2, 2015
    PSL/Jupiter
    Im impressed.
    Only story I can add was that I snapped all 8 rods and bent 7 pistons in My lightning. Multiple holes all throughout the block. Fun times.
    Think the cause of failure was a bad hi-low fuel pump relay, tons of boost and nitrous.
    Fun times.
Share This Page
