Engine replacement
Gene Kirk
GA
Hey guys, I’ve got a 17 with 33k miles on it. Casually rolling down the road and the oil pressure light pops up. I know there have been a thread or two on the subject. Long story short after about a month at the dealership I’m getting a new engine. My question to you guys is should I keep it? I have some long term concerns. Any advice would be appreciated.
91Eunos
Hill country, Tejas
Just my $0.02, but assuming any underlying cause is addressed you’re essentially resetting the clock to zero miles on your truck. Clearly wear and tear (especially on the trans) is still a factor, but the biggest wear item is the motor/engine assembly.
I’d keep it if you’re otherwise happy with the truck.
A point of clarification here.
was the truck found to be low on oil? if so, had you not checked it recently? I’m not trying to point the finger at you here, just trying to get more info.
yeah, I agree with previous posters, at a minimum, you get a year warranty from the dealer on the labor, and the motor itself IIRC. if you’re on the fence, pick up an ESP.
Investigate ignoring the sasquatch77 troll, who has been banned 3 or 4 times now, and will be again soon.
Pacific Wheel
Reno, NV
Sorry to hear about your troubles. I'd probably do a little research on the dealer doing the work. I wouldn't let my local dealership rotate my tires let alone R&R the engine. I usually have to take my truck out of town (1 hour away) for warranty work. The out of town dealer is amazing though. They're also a roush dealer and they seem to have pretty intelligent techs. Not sure if Roush dealers have higher standards for tech but might be worth looking into.
Gene Kirk
Gene Kirk
GA
Actually about a month ago I took it in for an oil leak that I found in my garage. Dealer said it was a faulty filter and sent me on my way. When to low oil pressure light came on I immediately went to the dealership. After one week they concluded nothing wrong (this was on a Thursday). Friday they call and say the engine needs to be taken apart because they found metal in my oil.
kid icarus
Nintendo
You had multiple problems that are well documented here from others going through the same. Have them give you a trade value and get something else.
