Engine rebuild vs replacement
Braptor2012
Spokane, WA
Just picked up a project 2018 Raptor, with 160K. Bought with blown turbos, clogged cats and leaking oil pan. After some monkey wrenching and trying to get it to turn over, I think the engine seized up (spun bearing according to my mechanic). Also smell gas in the oil which is pretty conclusive. Curious to hear opinions on engine rebuild vs replacement. Besides cost difference, hoping to get it running with as minimal collateral issues. Weighing the costs of engine replacement with benefit of warranty and possibly better ROI vs less upfront monetary investment with rebuild but potentially chasing other issues. I know turbos and cats are a separate cost regardless...
714raptor
SoCal
You can get a full long block from Mountune
Or, if you want to go big, you can get their stroker 4.1L short block
GCATX
King Dingaling
Central Texas
If the cats are clogged enough, it's not gonna run at all. I learned this the hard way after doing an engine swap and new engine would not run either. LOL. Cut a 1" hole in the exhaust before the cat, damn thing fired right up.
Oh, and my story was the same, bought a non-running truck, was told the motor was bad, turned out to be cats. Not saying the original motor was in perfect working order, but we'll never know.
thatJeepguy
GA
The ideal combination of a cost effective and reliable repair is an OEM Long Block replacement. Tasca parts sells the long block for $4,356.
If you’re looking to upgrade to support more power, also consider RMB in addition to the Mountune options posted above. https://www.rmbmotorworks.com/17-19shortblocks
Dear lord i just read the description on that rmb stage 3. Honestly that thing would probably smoke a raptor R. And no ADM!
B
Braptor2012
Spokane, WA
Bought knowing the turbos were leaking oil into the cats - so that was one of the first things we tried was cutting the downpipes just above the cats - it was better and had it running for a second until it wasn't :(
I may DM you, but did you replace with stock?
GCATX
King Dingaling
Central Texas
Mine was an old POS Chevy Zr2.
