GEN 1 Engine Rebuild Parts Suggestions.
MrVeteran51248
NW Iowa
So, my winter project of fixing the Raptor has taken a while longer than I expected. I am a broken veteran that has a hard time staying contorted and bent over in an engine bay. But my suffering aside, I had an issue that started a while back before winter and it started with what was a code for "Cylinder 1 Misfire", I started with plugs as they were Motorcraft's and I am running a Roush SC. When that didn't take and the code reappeared. I then did a compression test and Cylinder 1 failed at about 30 PSI max. I looked down the plug hole and thought maybe a valve was hung open with carbon, or a spring was broken. So I ordered a set of springs that were an upgrade from stock and went about the task of changing them out with a couple of universal spring compressors. That, was an adventure and quick reminder of the explosive energy of springs. I then was delayed searching for a better and safer valve spring compressor. I found it, but from what I found it is no longer being produced. But, I managed to find some and got one. Finished the right side of the motor. I then re-applied 90 psi to Cylinder 1 and bounced both valves open and closed to maybe knock some carbon loose if there was any. That didn't solve the leak issue. So, in my creativity and anger I created a smoke tester. A very redneck contraption that kind of worked, once the smoke overflow cleared. Then I blew air into cylinder 1 and had some smoke come up and out of the timing chain area. So history lesson and long story short. I am suspecting that I got extremely lucky and it appears that I did not damage the cylinder wall but I suspect that I lost some lands on #1 and it is no longer sealing. So I am guessing I am pulling the motor and rebuilding the engine. Looking at maybe the JDM Shortblock Rebuild Kit. Since the motor will be out seriously considering a set of headers or manifolds. leaning more towards headers as I can weld any cracks on them if that ever happens. Will also be sending the head and block off to get honed, and milled if needed, and have a valve job. I plan on reusing the new spark plugs, and the valve springs, as they all have anywhere from 0-30 miles on them. I am going to list out the parts I am considering. Let me know if I am overlooking something or if you have a better suggestion and why. Thanks all, sorry for the whole run down. but figured it better than running around to see all my old posts.
JDM Shortblock Rebuild Kit - $3,800 - https://www.teamjdm.com/raptor-f-150-6-2l-2010-2014-engine-shortblock-rebuild-kit/
Kook's long tube headers and cats - $3,920 - https://www.teamjdm.com/kooks-2010-2014-raptor-6-2l-long-tube-headers-and-green-catted-y-pipe/
Stiffler's Traction Bars
- $590 - https://www.teamjdm.com/2009-2014-f-150-raptor-stifflers-long-traction-bar-system/
Full Fluid Changes - Differentials, Transfer Case, Supercharger, trans filter and fluid top off, all coolants. Will use Valvoline Synthetic Blend 5/30 in the engine.
Considering Fuel injectors - either 47lb replacements, or higher to run E85 and a tuner.
Will also be replacing -
Water Pump, Thermostat, Timing set, Serp belt, and obviously all the seals and gaskets.
Cost isn't an issue, but it is always a factor. Thinking I would like to improve on the motor, but I don't need to mortgage the house to pay for the rebuild. I am aiming to be well under $10k on this but, it is what it is. Lets see your lists and suggestions. Don't forget a reason too.
Justbob
MD
I’m still confused on where you think you are losing compression? Did you put a scope down the spark plug hole and look at the cylinder wall ?
thatJeepguy
GA
He probably smoked a piston ring…
how stout is the crank on the 6.2? Maybe find a stronger one?
MrVeteran51248
MrVeteran51248
NW Iowa
Wasn't aware of the crank being a weak spot, even with the S/C and the "stock" Roush Stage 2 tune. Still considering a tuner from JDM to make minor quality of life changes to the truck, but not too crazy.
SVTWillis
Law Enforcement Marine Corps
Norfolk, Virginia
The JDM tune is one of the best things I did to my Roush. Drives way better. 133k miles and still runs like new.
101,284
60,415
Gerth
