GEN 2 Engine noise
rmahone5
Monroe Michigan
Having engine noise on my 2017 ecoboost Raptor 49K sounds like a knock almost coming from I believe the right side of engine. Extremely loud on auto start but noise never goes away and now u can even here it resonating out the right side exhaust pipe when approaching truck from the rear. Curious to see if any other Gen 2 owners have had any engine noise or issues from motor.
1roadking
Look at post regarding engine knock. It’s a common issue and has to do with cam phasers and chain tensioner.
raisins
NJ
Been posting this on other threads to help members narrow down any possible issues they’re facing. My 2017 needed a longblock due to a rattle on startup. The rattle lasted several seconds on startup, then went away. Directly prior to dropping the truck off, I did feel a slight shudder while stopping at a light. Other than that, no other issues. I bought the truck with 7,193 miles and it went into the dealer at about 800 miles later. The notes on the paperwork stated the truck had an oil leak on the passenger side above the engine shield (?) and had low oil. They topped it off, symptoms persisted. After a bit of inspection, they found one of the piston skirts to be cracked.
They had the truck for a month and full longblock was replaced.
Take it to dealer OP
GCATX
King Dingaling
Central Texas
Read the 1st post again.
Members online
101,111
60,285
Selestial
