Engine Knock Need Help
Behrman
Beeville Tx
Hey guys I need some help . I have a 12 6.2l with 92K . Just had plugs done and have about 5200 miles on 5W-20 Penzoil Platinum oil change .
Today I took a 200 mile trip to Houston and when I pulled into parking garage I could hear my truck knocking/tapping . It was not doing this before I left and I have never noticed any rattle or knocking when starting truck up. The knock was hard enough to where my sister who knows absolutely nothing about vehicles asked what was wrong .
Oil pressure and everything was Fine no CEL light . So I started my trip home after Calling my dealer. I stopped at Bucees to fill up truck was still knocking when I left . When I arrived back at my house the knock was gone . It sounded like possible phasers or lash adjusters . Any ideas on what this could be ? I have an extended warranty but it won't do me any good if truck is not displaying issues when I take it infor service. I included a link to my YouTube that has video which you can clearly hear knock .
Tx State
Well-Known Member
I know these trucks are known to have loud valve trains but that does seem a little excessive. I also think mine is starting to get louder as well I might have it looked at here soon.
1BAD454SS
Exhaust leak or loose plug sounds like to me , i would do a re torque. Sounds like old 4.6 motors when they had a loose plug.
Sozzy12
Army
Montana
I was leaning towards the exhaust leak myself... Given the recent plug change, I'd start there.
MaTm
Plugs are a pain to do, but a good first check. Kind of sounds like an exhaust leak.
Behrman
Behrman
Beeville Tx
It is not plugs and not an exhaust leak that I can find. Going to take it by a mechanic I Know and leave it to try and at least get a diagnoses/opinion on what it could be
Sozzy12
Army
Montana
Do you have a mechanic's stethoscope? Only a few bucks at Harbor freight and great for narrowing down stuff like this...
Gotlag1789
Michigan
Suuuuper old bump, but any luck/further info on this?
my 2013 just randomly started doing this after a plug/oil change. 105k. I’ve only noticed it once the truck is warm and at idle. Seems to drive fine otherwise.
bwep
Mass
A buddy of mine made the exact sound. It's a broken plug. The noise is the arch snapping inside the porcelain. One of your 16 plugs is bad. Find it replace it and report back
Canuck714
San Antonio TX
Change your oil..
I Run 5-30 and if I've been running hard or getting close to a service mine will start making noise. Put fresh oil in it and boom quiet again for another 3500-4000 miles of abuse.
The oil starts to get a bit thin with age, so I assume some of the lifters dont get as "Pumped Up" as they should and have more slop in the valve-train...
Just my experience with the 6.2.. All 3 of mine have done the same thing.... Not as loud as this , but similar noise.
101,126
60,302
osvariitoreyes
