Eibach and front axle issues
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by Jace21583, Oct 23, 2020.
  1. Jace21583
    Jace21583 Full Access Member
    229
    130
    Jan 30, 2019
    41055
    Anybody else with eibach front springs having any front axle issues? I had eibach springs installed and now the boots on the axles are coming loose from the clamp, not tearing or anything, just coming out. The dealership, trucks still under extended warranty, said this is last time they are going to replace the axle. This will be the second time in a month it's getting replaced. And it's always the passenger side. Stock lca and uca if that makes any difference.
  2. Clord555
    Clord555 Member
    6
    Apr 19, 2019
    Sc
    My dealership is having install issues. Said they can’t get the alignment right and have to buy some alignment kit. Debating on going back to stick springs.
  3. Cmozz
    Cmozz FRF Supporting Member Supporting Member
    12
    14
    Aug 17, 2020
    Colorado
    Was just considering adding these - what years are your trucks?
  4. Jace21583
    229
    130
    Jan 30, 2019
    41055
    2018
  5. TravisHTX
    TravisHTX Full Access Member
    105
    93
    Apr 2, 2020
    Houston
    I haven’t had that same issue, but I only have 5k miles since my eibach install on my 2019. Maybe try crimping the ring a little tighter?
  6. TravisHTX
    105
    93
    Apr 2, 2020
    Houston
    I did have this problem. The shop that I took my truck to for the alignment said they needed to install a cam kit. I trust the shop that did the work.
Share This Page
