I’ve been on BFG KO2’s E-rated tires on the 17’ Raptor since about two weeks of ownership. All of my tires were so out of round that they could not be road force balanced, BFG replaced all four under warranty. C rated were on back order so they gave me the E-rated which are slightly more expensive for no additional charge.
I know the C was created specifically for the Raptor, but on my next round of tires I’m sticking with E. The ride is the typical off road tire ride, you feel the tread slow going, but smoothes out once you get speed. I liked the fact that is can take a heavier load. Obviously if you are in central coast Cali would be happy to swap rides to compare.
I was also thoroughly impressed with BFG and their customer support when I had the original problem. Ford was a nightmare to deal with. I finally decided to call BFG directly for the warranty claim while driving to work. Literally a five minute phone call. BFG called the authorized tire vendor who stated they were too out of spec and four new tires approved. No paperwork or waiting. That’s the way to do business.
For those who have owned Gen 1s. Have you run KO2s in E rated? How do they ride in comparison to the "C" rated tires on a Raptor, or for that matter on an F150?
I put KO2 E rated on my F250, however my old tires were E rated also. In this case the KO2s were a bit softer and a bit more compliant. And for the first 100 miles or so they felt like I was driving on jello.
Thanks.
My current truck is a '14 F150 SCREW ecoboost. For the first 2+ years of owning it I ran the KOs in 315/70-17, same as the first gen Raptor. They were D load rated. I put on KO2s in December and they ride the same from a firmness standpoint. I run my tires at 40 psi. The KO2s are a lot smoother at freeway speed and took a less weight to balance. The tread design is also a lot better in rain and snow. I live in the NW and drive in both frequently in the winter. BFG doen't make a tire to fit the Raptor in a C load rating, nor would you want to put one on if you could find one. Typically C load rated tires would be used with a 15" wheel on a smaller vehicle like an older Jeep Wrangler. When my 17 Raptor is delivered I will keep the stock tires and swap out to some different wheels since I think the KO2s are a pretty decent tire, especially for where I live. My $.02
