E brake routing with Deavers
dfinn
Utah
Recently got my Deaver springs installed by my local shop. I noticed this while parked slightly off camber
The bump stop is contacting the e brake cable. Should this be routed differently? Possibly under the springs?
roush_14
Rhode Island
This is good to know because I need to replace mine which got crushed in that same spot at one point.
Nex
RIP CoronaRaptor
Washington State
Keep in mind, I would check full droop to make sure that the cable is not hindering your springs.
roush_14
Rhode Island
Will do that, it will be on the lift when I change it so should be good if it has no tension running under spring I would think.
dfinn
Utah
Thanks guys, I’m gonna take it back in and have them reroute it underneath. It also looks like the passenger side leaf springs is rubbing on the exhaust. Is that typical with Deavers?
jondle
San Diego
FWIW, mine is also under. Mine does not rub the exhaust, but my exhaust dumps under the bed before the axle.
