Dyno Proven Power with Mountaintop Tuning Turbo Adapter Kit
CJ Pony Parts
Harrisburg, PA
Mountaintop Tuning Hi-Flow Turbo Exhaust Adapter Kit for the 2017+ F-150 Raptors. 6mm wider inside diameter with smooth machine for significantly reduced back pressure.
Click here to get your turbo flange kit
If you're looking to further boost the performance of your Raptor, than this Mountaintop Tuning Hi-Flow Turbo Exhaust Adapter Kit is exactly what you need! This all-new, American-made turbo exhaust adapter will replace your favorite Ford truck's stock catalytic converter adapter. It will help to increase your F150's exhaust air flow and decrease back pressure, allowing your EcoBoost engine's turbo to spool faster and reduce turbo lag. This kit is the perfect way to get a bit more boost out of your 3.5L engine, but also helps reduce your truck's exhaust temperature. Your new turbo adapter will work with both factory and aftermarket downpipes, and will easily install with fresh hardware from Ford (TEAINSTL1). Hurry up and grab your upgrade kit from CJ's now!
