DYI CAI How To: CAI, home fabricated!!
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by jesse, Jul 5, 2010.
  1. Badgerscab6.2
    Badgerscab6.2 Full Access Member
    322
    158
    Feb 11, 2012
    Fox Valley, Wisconsin
    This is a cool cheap idea, but correct me if im wrong. If thats a METAL pipe hes using, wouldnt the heat off the engine heat up the pipe after a while and make the air going in hot too and thus defeat the purpose of a "CIA"?
  2. Squatting Dog
    Squatting Dog FRF Addict
    8,616
    4,101
    Jun 1, 2011
    Kansas City, MO
    The metal intake pipe would have little or no effect on incomming air charge because of the air velocity through the tube. If the incomming air charge was to dwell inside of the tube then it would increase in temp. Since the air inside the tube is constantly moving while the engine is running, the heat would not be transfered..
    The only exception is if the tube diameter is too large, then the intake air velocity would slow down and slight (a couple degrees) heat transfer would..
    -Greg
  3. RatedSVT
    RatedSVT FRF Addict
    37
    1,302
    134
    Oct 26, 2011
    Sleepy Hollow,IL
    Damn I was hopping their would be finished picks
  4. Yogurt Raptor
    Yogurt Raptor Full Access Member
    150
    8
    Mar 14, 2012
    Orange Beach, Alabama
    Me to I keep going back to This Thread to see what finished product looks like. Its a damn good idea just not sure about it for my truck??
  5. EatsPrii
    EatsPrii Full Access Member
    94
    22
    Apr 21, 2012
    Twin Cities
    I'm glad this was resurected. I've been thinking about doing a similar mod. Except rather than K&N, I'd like to put the Donaldson filter that Volant uses in the box. His comment about 3" hose is a great idea. 1) Cheap 2) Flexible 3) Easy.
  6. Squatting Dog
    8,616
    4,101
    Jun 1, 2011
    Kansas City, MO
    larger is not always better...
    -Greg
  7. EatsPrii
    94
    22
    Apr 21, 2012
    Twin Cities
    What's the stock diameter of the intake? Isn't it about 3"? I'm not thinking larger... just more direct with less resistance. Call me crazy, but the open box style of some of the CAI's and the hi-flow filters seem to allow a certain amount of risk of engine damage. I like the Donaldson filter because it maintains a large amount of surface area for both filtration and air flow.
  8. Badgerscab6.2
    322
    158
    Feb 11, 2012
    the more I look at this thread now the better idea Think it is, so I checked racepartsolutions.com. The website on those silicone couplers the OP used and it looks like you can get all the parts needed on that site!! the piping aluminum or SS, couplers and clamps. Price varies depending on the metal you choose for pipe. Thinkin its a 45degree mandrel bend and he just cut it on the throttle body intake end? My guess is its all 3" or 3 1/2" since its looks same diameter as the stock intake box. just have to measure that
    pipe
    Mandrel Bent Pipes & Accessories, Aluminum | RacePartSolutions.com
    coupler
    RPS Silicone Hoses, Couplers | RacePartSolutions.com
    clamps
    RPS Silicone Hoses, Stainless Steel T-Bolt Clamps | RacePartSolutions.com
    Hope this helps
    -Jeremy
    EatsPrii likes this.
  9. EatsPrii
    94
    22
    Apr 21, 2012
    Twin Cities
    Wow! Yeah - it helps! That's a realy cheap solution. When you put it all together, it's about $50 in pipes, joints and clamps.
  10. RatedSVT
    RatedSVT FRF Addict
    37
    1,302
    134
    Oct 26, 2011
    Sleepy Hollow,IL
    Badgerscab6.2 you going to give it a try?
Share This Page
