Duratrac tires
Huck
Chicago Sw Burbs
I just put a set on mine. Much quieter then the ko2’s so far. I expect the same performance as they were one gen 1
NASSTY
ME
Mine are a little louder than the stock KO2s were. They are Load Range D and the ride is a little rougher than the Load Range C KO2s, but not bad.
Raptor911
Ashburn, VA
According to tirerack:
Duratrac:
315/70R17 >> Load range D >> 61 pounds
35x12.5-17 >> Load range E >> 68 pounds
KO2s (OEM):
315/70R17 >> Load Range C >> 65 pounds (for a C tire, this is heavy)
I assume your increase mileage was due to adding 3 pounds per corner?
Mine don't seem loud at all. lost .4 mpg though (35x12.5-17)
xrocket21
Maine
Duratrac:
KO2s (OEM):
Im not sure why. I guess its a little taller and a little heavier. (34.4" vs 34.8")
Raptor911
Ashburn, VA
Load range is why it is heavier:
C >> 6 ply
D >> 8 ply
E >> 10 ply
I never get load range E as I feel is over kill for a daily driver. But if you off-road or tow and you want a stout tire then you want E.
I think the duratrac in 315/70/17 is the perfect tire. Light, great all around traction (incredible in snow), Load range D (stronger than a 6-ply but not as heavy as a 10ply) and with the aggressive tread pattern, it looks great.
xrocket21
Maine
I realize why it is heavier, I meant I wasn't sure why I lost a half mpg.
I live in a rural area and drive dirt roads daily, so 10 ply isn't the worst thing in the world for me. Kinda wish I knew about the 315 and the d rating though, but oh well.
Raptor911
Ashburn, VA
There are guys here that run Toyo's and and some of those tires are 80 pounds. With an 80 pound tire they are losing 2mpg.
