DRL Trouble
msu50000
Michigan
2017 Raptor
I'm having some trouble getting the DRLs to only the hood lights and marker lights. Cannot get the headlights to turn off. I've tried multiple ways thru FS to adjust and am not getting anywhere. I've been able to do this on a previous 2020 Raptor, 2023 Lariat and 2017 Superduty so I'm fairly comfortable working through FS. Screenshots below from the BCM module config screens, both the hexadecimal and menu based. Any insights are greatly appreciated, just want the hood lights/marker lights as DRLs...
Antho
That would be my guess. Haven’t messed with that Gen2 in awhile
M
msu50000
Michigan
Well, still having issues with the DRLs on my 2017 Gen2.
Here is where the truck currently sits, I've used the original AB file to revert back to stock and then change to what is noted in Livin's ForScan log.
I've tried both the As-Built and menu based service procedure in ForScan. Images below.
If anyone has any ideas, it is much appreciated.
feelinold
Alaska
Maybe try and change your DRL conditions from option A to Option B and see what happens. I myself also have a 2020 F-150 Raptor with the 3.5 HO and my conditions are set to option B for some reason that's how my factory as built was set So maybe yours might need to try that too.
101,364
60,451
SOBRaptor
