Does rigid make a “[email protected] bracket?
Discussion in 'Ford Raptor Lighting Forum [GEN 2]' started by chujk1985, Apr 8, 2018.
  1. chujk1985
    chujk1985 Full Access Member
    33
    78
    4
    Nov 15, 2017
    Installing my rigid fogs with the diode dynamics mounting bracket.
    Does anyone know if Rigid makes a “shorter” mounting bracket? When mounted the bumper is covering a small section of the bottom of the fog.
  2. Uncas
    Uncas Full Access Member
    60
    26
    Dec 8, 2017
    Heading to Colorado
    Same Issue with the D-SS, I talked to Rigid Support and they are passing it on to the engineers since I was the 10th call they have had about this. Email them and we'll see if we can get them moving faster.
    https://www.rigidindustries.com/contact-us
  3. chujk1985
    33
    78
    4
    Nov 15, 2017
    Thanks for the info! I am seeing others mounted pretty flush with the bumper cut-out. It seems like there are some shorter brackets out there?
  4. Uncas
    60
    26
    Dec 8, 2017
    Heading to Colorado
    You find them, post it. I would love to pull mine up about 1/2 inch.
  5. Uncas
    60
    26
    Dec 8, 2017
    Heading to Colorado
    The more I look at the website, I think they changed up the bracket.
    I would love this height........................................................... Which looks nothing like this.
  6. chujk1985
    33
    78
    4
    Nov 15, 2017
    I was thinking the same thing, but I couldnt be certain since the "shape" and "features" of the bracket look the same. I didnt know if it was just the photo that made it look different. I could not find any dimensions of the two.
    Also, I was wondering if the bracket could be fitted going the opposite way. Instead of pointing the bracket towards the front of the light, point it towards the rear. I havent had the time to experiment, but it is probably unlikely that it would work.
    ---------- Post added at 11:39 AM ---------- Previous post was at 11:38 AM ----------
    Did you flip the front housing to get the "Rigid" lettering right-side up?
  7. Uncas
    60
    26
    Dec 8, 2017
    Heading to Colorado
    1. I tried that, but it would not work.
    2. Yes, don't tell Rigid.
  8. downforce137
    downforce137 Full Access Member
    581
    292
    Jan 5, 2016
    In Diana
    two things..
    1.i think your rigid brackets are on backwards..
    2. can the diode brackets be on the wrong sides of the truck? I thought the bend was supposed to go up in the rear of the bracket/truck if that makes sense.
    CROOKS likes this.
  9. CROOKS
    CROOKS Full Access Member
    92
    17
    May 9, 2016
    Spin the bracket around and mount the light as high as possible.
    [​IMG]
    Rigid D2 fog, spot, flood on an L channel of aluminium.
    Uncas likes this.
  10. chujk1985
    33
    78
    4
    Nov 15, 2017
    oh, so it does work. Uncas up above was saying it would not work for him. I will give it a try.
Share This Page
