Does anyone have this chase rack? I’m considering getting one but didn’t know how good it was.
Caleb Sousley
Missouri
Another question would be a good bed cover to go along with the chase rack if that’s possible!
Thank you
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
Thank you
for offroading, absolutely not. any rack thats only bolted to the bed rails will fail. the vibrations of dirt driving will cause it to loosen and damage your bed. if you arent going offroad, then sure, go for it.
@RDFTS has a couple pics of something similiar that was on his truck
Caleb Sousley
Caleb Sousley
Missouri
Got it thank you! Is there better options I’m assuming for off-road? I don’t plan to off road a ton if any at all but just curious
Antho
Its the ADD rack that is also on the Shelby Raptor and offered by ford performance. The one offered by shelby has a dual tire carrier that mounts to it but i have only seen them on the shelby and not offered for sale anywhere. ADD does offer the center mount tire carrier but basically takes up a lot of space. So really, Its a huge light bar mount...
https://www.addictivedesertdesigns.com/ford-f150-raptor-chase-rack-C115802800103
zombiekiller
OG BooBooRunner
New Orleans
Impulse offroad in utah makes a proper chase rack that mounts to the bed bolts and works well offroad. its the same chaserack that they use to put on the raptor assault trucks ( not sure if they still do).
are you after the look or the light mounting?
for the sake of your bed, if you are looking for light mounting, A-pillar lights will be a better option for offroad, and they won't potentially tear your bed apart while offroading.
if it is the look that you're after, there isn't a good option, as the chase racks are steel, and the bed is aluminum. The bed is designed to flex, the chase rack is not.
DocSpooK
TechsAzz
Didn’t know ADD won’t sell the tire mounts, they are fantastic. I have jumped mine dully loaded no problem.
DocSpooK
TechsAzz
Disagree. I have been to several events with mine and it is still going strong. Come to TRR in May and see for yourself. ADD has a stiffening bar below the back window so it has good structure. I jump mine with tires and recovery gear in the back.
DocSpooK
TechsAzz
Thank you
Sorry, couldn’t figure out multiquote. It is kinda gaudy, but definable functional. I have the Shelby one and it is tough. My truck is not a street queen and zero issues. I did mod the tire carriers for wider 37s too. Being able to lower the light bar got me into the house garage too.
Also I still have my full bed for regular truck work, just take out tires. Try moving furniture with a regular bed rack.
here, on frf
first off, where the hell have you been????
regarding this bed rack.... some that are mounted to the bed bolts work fine. its the ones that are only mounted to the bed sides. i had to fix a guys truck with a roof top tent mounted only to the bed rails on our wyoming run last year. have had several come into the shop over the years with loose and damaged bedrails. so based on what i have seen, i cant ever recommend them. im glad yours is holding up though
